Question about Microsoft Windows XP Home Edition
Switching to other user's account using the fast switching option
Hello! experimenting after reading the article" speeding up computer with few tweaks" cause me problem. I don't know if I done it incorrectly. After reboot, I noticed that switching to other user's account won't work properly... you have to log off first before doing so. I did checked the "use fast users switching option" on the select log on/log off option but that won't work.Can you please help me resolve this problem. Thanks a lot.
Jrnickm
The best suggestion i can give is reinstall ur os and reboot it but plze dont reboot it ur self maybe u hev done something wrong .boot setup is nery imp and has to be done very clearly.and plzze see that u hev install aharmful softwere check th pc repair softwere which is avilable in google
Posted on Jan 11, 2008
6ya staff
SOURCE:
I haven't used my tablet in long time can't remember my user/password how can I reset to use
    1. Follow these steps:
      1. Pull down from the upper-right corner of the screen to display the Quick Settings panel.
      2. Touch your user account icon to lock the tablet. ...
      3. Tap the button for the user account or restricted profile to which you want to switch. ...
      4. Unlock the screen by using that unlock method.
      Setting Up a Tablet for Multiple Users ' Getting Up to Speed ...
      www.quepublishing.com/articles/article.aspx?p=2272156&seqNum=5
    Feedback
  1. How to Add Security with the Android Tablet Lock Screen ...
Dec 19, 2015 | Tablets & eReaders
How can i add guest icon to my startup screen
If your computer is not part of a domain. First check if the Guest account is turned on. You will need to be an Administrator. The guest account option is in the User Account control panel. Click Start > Control Panel (in the right hand column). Select the link for User Accounts. Click on the Guest account to turn on the option.
Then you should be able to see an option for switching to the Guest account when you log out of your current account or get to the select user screen when you turn on/restart the computer. (The default is to log in the most recent user.)
If your XP Pro computer is part of a domain, you need to use the Local Users and Groups section of Computer Management. That's in the Control Panel under Performance and Maintenance > System Tools. Right click on an account and select Properties to enable or disable the account.
I hope this helps.
Mar 19, 2014 | Microsoft Windows XP Professional
I forgot my sony vaio e series password
Hiamaurycastil...
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 21, 2011 | Sony Computers & Internet
My screen appear you are a victim of software counterfeiting how to erase this or resolve it thank u
Start Windows Registry editor and delete the folder "WGALOGON" located in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\CurrentVersion\WinlogonNotify. Delete all references in your registry to WgaTray.exe
Another alternative suggest that three files are installed Windows XP System Folder:
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dl...
The wgatray.exe process makes the check for genuine windows software. You can disable WGA by removing the execute bit on WgaLogon.dll. That way, winlogon can't call it as a notification package at boot, and since WgaLogon is responsible for running and maintaining WgaTray.exe, no more tray popups either.
To change the execute bit of WgaLogon.dll, first turn off Simple File Sharing. Now right click the file in Windows Explorer and open the Security Tab. Hit the Advanced button, uncheck the Inherit box at the bottom, hit the Copy button, then hit OK. Go through each listed user/group and remove the "Read & Execute" permission for that file, leaving the "Read" permission as-is.
Hit OK to apply the permission changes and close the file properties dialog. Restart the machine. You can now turn "Use simple file sharing" back on, if you want.
A third alternative posted on the internet suggest that users clear the content of file data.dat located in the following directory:
C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage\data
Save the data.dat empty file and change the attributes to "Read Only" - Restart you computer. Or start your PC in Safe Mode and delete the following files from Windows system32 folder - wgalogon.dll spmgs.dll wgatray.exe The WGA setup file is in C:\WINDOWS\SoftwareDistribution\ Download\6c4788c9549d437e76e1773a7639582...
If you don't use "Fast User Switching", you can disable the Windows XP Welcome Screen if you are logged in as an Administrator. This will remove the initial WGA Warning Screen:
1. Click on Start -> Control Panel ->User Accounts
2. Click on "Change the way users log on or off"
3. Uncheck "Use the Welcome Screen" - Choose Apply
4. Close the User Accounts window and the Control Panel
5. The next time you reboot your computer, the classic login prompt will be used
To enable Fast User Switching, you must also enable the Use the Welcome screen option. Also, Fast User Switching cannot be used when Offline Files are enabled.
Disable wgatray.exe - Some users are claiming that removing the WGATray.exe (or killing the WGATray.exe process) are working for them. Here's how to search for WGATray.exe file - Screenshot
None of these methods are guaranteed to work and people are just experimenting. Meanwhile Microsoft is not willing to relent to crackers this time and are planning to release an update of WGADiag2.exe utility in the next few days.
WGADiag2 will also fix the problem with registry key permissions may cause the installation of Windows Genuine Advantage Notifications KB905474 to fail from Windows Update:
Here's a manual fix provided by Microsoft. These permissions can be repaired using Registry Editor as follows:
1. Click Start, and then click Run
2. In the Open box, type regedit, and then click OK
3. Expand HKEY_CLASSES_ROOT
4. Locate the subkey HKEY_CLASSES_ROOT\LegitCheckControl.Legi...
5. Right-click the subkey and select Permissions....
6. Ensure that Administrators allowed Full Control permission
7. Repeat steps 3-6 for the subkey
HKEY_CLASSES_ROOT\LegitCheckControl.Le...
Microsoft has also published a kB article if the Windows Genuine Advantage (WGA) validation check process does not validate successfully on a Microsoft Windows XP-based computer, and you receive one or both of the following error messages:
Product Key Inaccessible 0x80080212
This problem occurs when you do not have the appropriate permissions for the Windows Genuine Advantage\Data folder. In the Permissions for Users section, make sure that Read & Execute, List Folder Contents and Read permissions are given. If the previous steps fail, start the computer in Safe Mode and rename the %allusersprofile%\Application Data\Windows Genuine Advantage directory.
May 20, 2011 | Computers & Internet
The windows does not asking the password it directly loading my personal settings...even i changed the password ....i cannot accessing the password protection..please what i can i do for this??
First of all, Open the Control Panel, then go to User Accounts.
Double click the user accounts. A window will pop out with options with user account info.
In the "Pick a Task" section, select the option "Change the way users log on or off." After selecting it, a window will show two options with check boxes.
The first option with the check box is "Use the Welcome Screen." Turn this option off (uncheck it).
Do not select the second option "Fast User Switching," uncheck it also. So, we have to keep both the options unchecked. Your issue will be resolved with these steps.
Jan 30, 2011 | Microsoft Windows XP Professional SP2
How to remove logon window
The way to stop the logon window is to have only one user registered on the computer, and to remove the password from the login account. All of this can be achieved through Control Panel/user accounts. If this helps, please rate me! :)
Jul 17, 2010 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
How do you remove the log in page after start up?
If you have windows XP:
1) Click on Start
2) Click on Control Panel
3) Double-click on User Accounts
4) Click on "Change the way users log on or off"
5) Uncheck "Use the Welcome Screen" (note: this will also disable "Fast User Switching")
6) Click on Apply Options
7) Close the User Accounts window and the Control Panel
8) The next time you reboot your computer, the classic login prompt will be used
Jan 14, 2010 | Compaq Presario 6020US PC Desktop
No user profiles are displayed at login screen. Instead there is a field to enter ID & PASSWORD. Some thing happend to my Computer. User accounts are not displyed, instead i can see user name and...
To resolve this issue, perform the following steps:
1. Open Control Panel.
2. Double-click the "Users" or "User Accounts" icon.
3. Click on "Change the way users log on or off". If you are presented with a message saying "Fast User Switching cannot be used ... etc.", click Cancel.
4. On the "User Accounts" main window, check the option "Use the Welcome screen".
5. Click "Apply Options".
6. Exit the "User Accounts" applet & restart your computer.
This should restore back the way you used to log into the computer.
Dec 06, 2009 | Microsoft Computers & Internet
User Id
Enable or Disable Fast User Switching Note: To enable Fast User Switching, you must also enable the Use the Welcome screen option. This feature cannot be used if your computer is a member of a domain. To enable Fast User Switching:
  1. Log on to the computer as an administrator.
  2. Click Start, click Control Panel, and then click User Accounts.
  3. Click Change the way users log on or off.
  4. If it is not already selected, click to select the Use the Welcome screen check box.
    NOTE: The Use Fast User Switching check box is unavailable until you click to select the Use the Welcome screen check box.
  5. Click to select the Use Fast User Switching check box, and then click Apply Options. Quit the User Accounts tool.
Please don't forget to rate this solution.
Jun 15, 2009 | Dell Latitude C610 Notebook
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
