I bought a new 19 in samsung and have now wall mounted it but can't see how to removed the stand for the base plate!!
    Scholar:
  • 79 Answers
There should be screws that's holding the stand for the base plate. Find the screw at the back and use a philips scredriver to unscrew it. Try lying the front of the tv flat (make sure that the surface is padded, so as not to damage the tv) when you unscrew it, or even lie it upside down just to take out the screws. You will find it more difficult to take out the screws if you do it with the tv standing up.
Posted on Nov 19, 2009
How do I remove the base pedestal plate from our Conia CL3201FHD television so we can wall mount it?
most have a trim plate at the back of the stand that when removed shows up 4 screws that can generally be used in the wall mount bracket holes
Dec 12, 2015 | Televison & Video
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
I am trying to wall mount my LG M197WDP - PZ 19'' TV but it has an ugly spigot that fixes to the free standing base. How can I remove this spigot? Thanks Dave
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
Oct 22, 2009 | LG Televison & Video
Picture remains for few seconds then screen goes blank, sound remains on
I had this problem on my 42" Philips LCD. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 01, 2009 | Samsung SM932MW 19 in. LCD TV
How to remove stand from a samsung syncmaster 910mp
It's usually 2 screw at the base of the TV, at the rear. Loosen or remove the screws and the base should slip right off
Sep 01, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
tom
Dec 21, 2008 | Hyundai Computers & Internet
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Non wall mountable samsung tv
Take the feet off. See the manual.
May 24, 2008 | Televison & Video
Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Sep 15, 2007 | Samsung SyncMaster 970P 19" LCD Monitor
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
