Question about Halex Toys
The top of table got wet and puck doesn't float right. Is it repairable
10 basic rules rules for hockey
1. The first player to accumulate seven (7) points wins the game.
2. When the puck enters and drops inside a player's goal, the player's opponent receives one point (unless play had been suspended by the referee or the offensive player had committed a foul during or prior to the shot.)
3. After each game, players will alternate tablesides.
4. The player scored upon receives possession of the puck for the next serve.
5. A player may hand serve the puck only after it has entered his goal.
6. A player may play with only one mallet on the playing surface at one time. Violation results in a foul.
7. The puck may be struck with any part of the mallet.
8. The puck cannot be "topped" by lifting the mallet and placing it on the top of the puck. This cannot be done at any time whether before a serve or after a serve during play. Violation constitutes a foul. Using the mallet to bring an airborne puck to the table or opponent's goal is not a topping violation no matter which side or edge of the puck is contacted.
9. Only one puck may be in play at a given moment.
10. A player has seven (7) seconds to execute a shot, which crosses the centerline. The seven (7) seconds begins as soon as the puck enters and remains on that player's side of the centerline. Violation of this rule is a foul.
Source: http://www.airhockeyworld.com/usaarules.asp
Hope that helps!
Sep 16, 2013 | Sport & Outdoor - Others
Can you use the same pucks on every size shuffleboard table?
You could; however it is recommended that you use smaller medium pucks on tables 12 feet or smaller. Here is a great site for smaller table pucks -
http://cheappricelowprice.com/Sun-Glo-Spangler-Medium-Shuffleboard-Pucks_B0050ZNJGW.html
Aug 20, 2012 | Sport & Outdoor - Others
How should I properly hold a table shuffleboard puck?
There are two effective ways to shoot a shuffleboard puck that I know of. First try holding the puck between your index and thumb finger, allowing your middle and ring finger to drag on the table. I recommend shooting off center. The second shooting method is to spin the puck clockwise using your thumb and index finger.
What are the rules in official air hockey games?
In official air hockey games, there are basic USAA rules that the players need to play by: Players can stand anywhere around their side of the air hockey table (center), but cannot go to the sides. Players cannot touch the puck (palming). If any part of their body or clothes touches the puck, a "palming foul" is called. Players can hit the puck with every part of the mallet, besides the bottom part. There should be only one puck during gameplay. A player can use only one air hockey mallet. A player cannot place the mallet on the puck in order to slow it or stop it (topping). When the puck is on the center line, both players can strike it. Once the puck is in the player's side of the centerline, he/she has 7 seconds to strike it back. For more rules, check out these websites: http://www.justairhockeytables.com/air-hockey-tables/airhockeyrulesarticle.cfm, http://www.ehow.com/facts_4868311_official-air-hockey-rules.html, and http://www.sportssearchdata.com/articles/606/1/Basic-Rules-of-Air-Hockey/Page1.html.
Aug 08, 2012 | Sport & Outdoor - Others
What are the rules of Air Hockey?
Here are some basic rules as defined by the USAA:
  • A face-off or coin toss decides which player gets the first possession of the puck.
  • The first person to score 7 points by shooting the puck into the opponent's goal wins the game. When the puck breaks the horizontal plane inside the goal, a point is counted, whether or not captured by the electronic scoring device.
  • Once the puck is on a certain player's side of the center line, he/she has 7 seconds to hit the puck back across the center line. Otherwise a foul is committed and the opponent receives possession of the puck.
  • Placing one's mallet on top of the puck, known as topping, is a foul. Here the opponent receives possession of the puck.
  • A player cannot touch or strike the puck with any part of his/her body or with any object other than the mallet. Doing so causes a foul and possession changes hands.
  • If the puck is on a clear path into the goal and the player stops it with anything other than the mallet, this is goaltending. Here the opponent receives a free shot.
  • Hitting the puck when it is on the opposite side of the center line, or crossing the center line completely with one's mallet causes a foul. Here the opponent receives possession of the puck.
  • Red lines in the air hockey should not be crossed by the air hockey mallet. (Catalan Champion Chip)
  • If there is a red line on the goals, it means that you cannot keep the air hockey mallet behind the red line. (Catalan Champion Chip)
  • If the puck leaves the table, a foul is called on the player that caused the puck to go out of play due to offensive motion and the opposing player gets possession of the puck. Generally, when a player causes the puck to leave the table with a forward motion of the mallet, even defensively (known as charging), the foul is charged on them. An out of play foul results in the opponent receiving possession of the puck.
  • The players playing cannot touch the puck at any time during pl ay, but if one player scores they can put the puck in loser's side.
Jul 25, 2012 | Sport & Outdoor - Others
How should I clean my air hockey table?
The best way to clean the surface of your table is with isopropyl alcohol and paper towel. Either spray it on the table surface with a spray bottle, or cover most of the bottle's mouth with your thumb and shake a little bit of it on the table at a time, so as not to use too much at once. Dry it off immediately with the towels, so that the alcohol doesn't soak up into the table surface. There is on important thing you have to remember, do not clean the inside of the table rails! The dirt and grime on the inside of the rails actually helps keep the puck from flying off the table.
Which Air Hockey table should I buy?
If you want an approved for USAA tournaments then you can check out any of the 8 foot long Dynamo Air Hockey table, just stay away from the "Hot Flash" series.
In the "Hot Flash" Air Hockey tables the painted rails make the puck fly off a lot, and fluorescent table-top makes it hard to see the puck.
A new Dynamo table price varies from $1500 to 2500$ so you should take it into consideration.
When the coffee grounds dump into storage tray, it doesn't stay in the puck shape it used to
When things get wet to they tend to spread apart when pressure is released - normal thing to happen. Only option is to use orange juice instead of water.
May 20, 2012 | Gaggia Titanium Espresso Machine
Air flow hockey table
We made a fixture that allows us to clean the table top. We took a piece of wood larger than the fan opening, drilled a hole in it, and installed an air fitting for use with our home air compressor. WIth the fans removed, we run the compressor and hold the fixture against the bottom of the table. That forces all that air to exit out the table surface. To concentrate the flow over problem areas we cover sections of the table during the process. Also, you may need new pucks too if they are old and worn.
Dec 09, 2008 | Dmi Sports Air Hockey Table Dmi Goal Flex...
Toys Logo
62 people viewed this question
Top Halex Toys Experts
Stitch85
Level 1 Expert
ray gallant
Are you a Halex Toy Expert? Answer questions, earn points and help others
