Question about Radio Communications
I have a cobra 142 base, and the receive is all most clear out. where should I start looking for the problem?
    Guru:
  • 773 Answers
Check the RF gain knob. It should be all the way up. If the knob is bad, this could be the problem. You can un solder the wires from this knob, and hook them together to give you max gain, if your receive is back when you do that, the knob is bad.
You can replace the knob, (Call cobra for the part) or you can leave it soldered together, put some heat shrink on it so it doesn't short, and use it like that.
It doesn't really need RF gain.
Now on that radio, the RF gain is on a double knob with the SWR calibration. RF gain is only 2 wires, and the SWR CAL is 3. You would take the 2 wires next to each other and hook them together.
If there is still no receive, then the radio needs a tech. A part has failed in the receive section of the radio in the RFgain section. Probably a resistor lost its value.
Posted on Nov 20, 2009
Wiring a DM502b mic to a Cobra 142 GTL
  • Factory Microphone Cord Wiring Information:
    (Shield = Mic Ground)
    (White = Mic)
    (Red = PTT Transmit)
    (Blue = PTT Receive)
    (Green = Up)
    (Yellow = Down)
    (Black = Up/Down Common)
    (Orange = B+ (NONE)
Oct 23, 2016 | Cobra Radio Communications
I have cobra ca61 desk mic i need it wired to my cobra 142 gtl home base. the base has 5 pins so i need my mic to be wired for 5 pin... any ideas?
cobra 5 pin to 4 pin adapter on ebay around $5.00
http://www.ebay.com/itm/WORKMAN-C4P5C-CB-RADIO-MICROPHONE-ADAPTER-5-Pin-COBRA-TO-4-Pin-COBRA-/121655850211?hash=item1c5340f4e3:g:e0AAAOxy2YtRsJ8n
Apr 10, 2015 | Cobra Radio Communications
I need to wire a 4 pin to a 5 pin mic turner plus 3 to a cobra 142 GTl
pin#1 audio lead #2 audio shield #3 receive control #4 ground #5 transmit control
Apr 30, 2014 | Cobra Radio Communications
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
Problems with Cobra 142 GTL
the diode and missing resisters are and caps are probably the culprits.
Feb 01, 2012 | Cobra Radio Communications
I got a 142 cobra base i need to find 12 volt on the main board to put a trb-x2 (echo board)
look at the power knob inside the radio. With the face, facing you, it should be the tab on the left. Depending on what year it is it could be a pinkish wire..
That is the switched 12v off the power knob. Use a digital multimeter to make sure.
Oct 23, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Low dead key on my radio
If it is a 142 GTL your A.M. power is VR6 . Good luck and be carefull and DON'T get carried away remember AT YOUR OWN RISK NO LIFE GAURD ON DUTY!!!! You should'nt have any problems though......Dan
Apr 01, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
No recieve on virgin cobra 142 gtl,
seems to me that the audio ic of the cobra 148gtl brokedue sudden change of voltage from power suplly or flactuation. ta7222p
Jun 07, 2008 | Radio Communications
Radio Communications Logo
78 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
