Question about Microsoft Outlook 2002 for PC
Relay access errors using Microsoft Outlook 2002. Checked setting and the server req. athentication has been checked. Number following error is 554 5.7.1
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
Please check your firewall settings to prevent the error message. You will need to open your anti-virus (if a paid subscription) and allow outlook the access.
Also, some email host have a limit on how many times a day outlook can "relay" or retrieve messages. I believe the default is set to 250 a day. I am not sure if you are exceeding this amount but you can log into your email account and check.
Please let me know if you have any questions.
Posted on Nov 19, 2009
Microsoft Outlook Express error. How to stop it?
'421 4.7.0 Not allowed.' means that your account isn't allowed to send through this particular server. Perhaps you changed your password, or your account expired of something like that.
May 28, 2015 | Microsoft Outlook Express
How to correct Ox800cccOD error
Sounds like a Proxy Server issue.
  1. Click the Connections tab. Go to LAN settings. Click Settings.
  2. If the Use a proxy server check box is selected, click Advanced.
  3. In the Do not use proxy server for addresses beginning with box, type *hotmail*;*services.msn*.
  4. Click OK three times.
  5. Start Outlook Express, and try to access your Hotmail account.
Source: http://support.microsoft.com/kb/259133
Jan 09, 2014 | Computers & Internet
Microsoft Web Access won't send mail
If you are trying to send or receive an email in Microsoft Outlook and the password doesn't work, you can check a number of different things. Microsoft Outlook validates your email account with your email provider using various settings. Once it has validated your settings, it will send or receive email. It is not only useful to set up your email correctly but essential if you wish to use Microsoft Outlook.
Gather all of the email settings for your email account. These will be located on your email provider's website in an FAQ or support section. If in doubt contact your email provider to provide all of the settings. Look for any of the following terms: POP, SMTP, IMAP, SSL, SPA, server, and port number. Make a note of all of these. Determine when the problem exists. Check if the problem occurs when sending an email, receiving an email, or both. If the password error only happens with either sending or receiving, this narrows down the source of the problem. Click "Start," type "Outlook" and press "Enter" to open Microsoft Outlook. Click "File > Info > Account Settings." Select your email account and click "Change." Click the "Incoming mail server" field, if your error was when receiving email but not sending. Enter the full "incoming mail server" address as provided by your email provider. If your email is "IMAP" then change the "Account Type" to display "IMAP." Click "More Settings > Advanced." Make sure that the incoming server "Port" number is the same as your email provider stipulates. If your provider requires SSL, then click "This server requires an encrypted connection (SSL)." Click "OK." Click the "Outgoing mail server" field, if your error was when sending email. Enter the full outgoing server address. Click "More Settings > Advanced." Make sure the "Outgoing server" port is correctly set. If your email provider requires encryption, then select the correct type from the drop-down menu. Click "OK." Click the "password" field and make sure you have entered the correct password. If your mail provider requires "SPA," then click the "Require logon using Secure Password Authentication (SPA)" to enable it. Click "Next" and then "Finish." Your password should now work. Hope it helps.
Aug 07, 2012 | Microsoft Exchange 5.5 Outlook Web Access...
Cannot connect Outlook 2007 to Yahoo server
I had in like situation some times and once I couldn't solve it and luckily for me could find out a good solution to my mind, which determined my troubles quite easily and moreover I hope that this utility will help in this condition too - pst password recovery.
Apr 21, 2010 | Microsoft Computers & Internet
Cannot connect to subscriber in China
Typically this error indicates that you are trying to send your Adhost email through Adhost’s mail server when you have not authenticated your email account to send mail. Our mail server authenticates you through your pop account. So when you check your email, our mail server authenticates your pop user and password, captures that IP that you are checking your email from, and adds that IP to our relay list. This list is flushed every 70 minutes. This means, if you try to send email after the relay list has been flushed and before you’ve attempted to check your email, you will receive this error.
How to fix the problem:
Fix #1 - reauthenticate on our server.
Remove any email from your Outbox. If you need to keep the message, you can move it to your 'Drafts' folder.
Click "Send/Receive". This will reauthenticate you.
Try resending the email.
Fix #2 - configure your email client to check for email before sending.
In Outlook, go to "Tools" and select "Email Accounts". Make sure "View or change existing e-mail accounts" is checked. Click Next.
Select your account from the list and click "Change".
Select "More Settings".
Select "Outgoing Server".
Check "My outgoing server (SMTP) requires authentication".
Select "Log on to incoming mail server before sending mail".
Click "OK", then "Next", then "Finish".
This will fix your problem
Or
Call Yahoo! Customer Service
USA: 1-866-562-7219 --- 1-800-318-0631
UK 020 7131 1000
Canada: 1-877-722 3755
Direct Number: 1-408-349-1572
Regards
manish
Mar 20, 2010 | Yahoo Mail
I am getting this error when trying to send email on Microsoft Outlook. I can receive but not send on Microsoft Outlook. I can send and receive through the mail server that I am using through Yahoo and...
Microsoft Outlook 2002 (XP) and 2003 From the Tools menu, choose E-mail Accounts. Click in the circle beside "View or change existing e-mail accounts." Click Next. Click the email account you wish to modify and then click Change. Click More Settings. From the tabs along the top, click "Outgoing Server." Check "My outgoing server requires authentication”. Also, make sure to check "Use same settings as my incoming mail server." Click OK. Click Next. Click Finish.
Microsoft Outlook Express From the Tools menu, choose Accounts. Select the "Mail" tab. Click the email account you wish to modify and then click Properties Select the "Servers" tab. Check the box next to "My Server Requires Authentication." Click the Settings button. Ensure that Use same settings as my incoming mail server is selected and click OK. Click Apply on the properties dialog box to confirm your changes and to close the window. Click Close on the Internet Account dialog box to complete the settings change. Click Close.
Jan 10, 2010 | HP Pavilion dv6000z Notebook
Microsoft Outlook 2002, error: Relay access denied - 554 5.7.1
I have seen around ten questions just like yours today. What email service are you using? This sounds like a problem with the server on the emaill side. It should go back to norm in a few days if not sooner.
Nov 19, 2009 | Microsoft Windows Vista Home Premium with...
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'a.tia62@yahoo.com'. Subject 'testing', Account: 'mail.eastern.com.ph', Server:...
Greetings,
this is a server rejected recipient error message for Outlook/ outlook express. mainly if this is a correct email address that you were trying to send the email on then you need to check for the configuration settings for Outlook express.
Goto Outlook express- higlight mail tab- select the user a/c- click properties on right- goto server tab check that server is
incoming: pop3.eastern.com.ph
outgoing: smtp.eastern.com.ph
click save
Regards,
TechSup1
May 01, 2009 | Computers & Internet
Microsoft Outlook - access denied 554 5.7.1
Got through the following links.May be it will help to resolve your issue.
Click Here 1
Click Here 2
Thanks
Mar 12, 2009 | Microsoft Office Professional 2007 Full...
I am not able to sending email from outlook express
Incorrect account settings.Remove your account and create new one in outlook.Check if u have installed any antivirus or firewall program blocking this.
Nov 01, 2008 | Microsoft Windows XP Professional
Microsoft Outlook 2002 for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
