Question about Hoover Tempo Widepath Upright Vacuum - Blue
My Hoover Tempo lost suction on the floor feature, but there is still suction in the nozzle. This is a very new vacuum-- used maybe 5 times.
    Genius:
  • Hoover Master
  • 1,474 Answers
Sounds like blockage or belt off between that area and sole plate /Check for blockage...
Posted on Nov 19, 2009
There is too much suction even with the hand tools on Hoover wind tunnel. Can i adjust suction somehow?
Hi, it's Jeremy from Crucial Vacuum.
If there is too much suction, adjust the nozzle control knob to a higher setting. The knob is located on the front of the vacuum at the bottom. For optimal cleaning efficiency a low setting should be used for most types of carpet and for hardwood floors, tile, and deep carpets use a higher setting.
You can purchase direct all of your replacement filters, bags, and accessories for your Hoover vacuum from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 17, 2014 | Hoover Self-Propelled WindTunnel Bagless...
My Hoover Tempo has almost no suction
Most vacuum cleaners have more than one filter (even bag-less vacuums sometimes). I have found that after being used a while the motor filter blocks up. I just remove it and use another vacuum to clean it out. Depending on the material you may be able to wash it in warm water or if you can get your hands on a new one just replace it. I found a link on youtube that may help you to locate and replace the filters: http://www.youtube.com/watch?v=wGsuVK8KTT0
Apr 04, 2014 | Hoover Tempo Widepath Upright Vacuum -...
I need help finding out why there is no suction with my hoover. The brushes are spinning and the windtunnel looks active but no suction either on floor or hose.
What model ? If there is suction from the end of the hose there could still be none to the floor. You may have a clog between where the hose connects to the nozzle and the intake behind the brushroll.
Turn the machine on and listen for a change in pitch of the motor when you disconnect the hose, verses having it attched to the nozzle.
Oct 20, 2013 | Hoover Vacuums
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
How do I clean the hoover steam vac floor cleaner machine
Nozzle Clean Out tool is NO LONGER AVAILABLE from Hoover. Hoover stopped making this part over 1 year ago, and it's not sold any more. What you'll need to do is remove the dirty solution thank, unscrew the one silver screw on the suction port of the clear window, then turn the machine upside down and remove the two silver screws on the bottom corners of the see thru window. This will then allow you to completely remove the see thru part to clean inside of it. Unfortunately with this model that's really the easiest way to do it now that the tool is no longer available.
Apr 18, 2010 | Hoover SteamVac F5914-900 SpinScrub...
After using my attachments I have a hard time getting suction when using upright again - how do I get the suction on my upright? It's a Hoover blue widepath Tempo~ thank you
It may be clogged underneath the vacuum where the roller is. Take the bottom plate off and look into the intake port. There may be some blocking the port.
Nov 09, 2009 | Hoover Tempo Widepath Upright Vacuum -...
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
My vacuum has no suction and does appear to be clogged.
make sure the door is on securely. check that the hose is installed in the correct place on the vacuum for the floor cleaning.
Sep 26, 2009 | Hoover Tempo Widepath Upright Vacuum -...
No suction on my vacuum. Hoover Tempo
try to clean between the roller and the tube to the hose
May 05, 2009 | Vacuums
Hoover Tempo Widepath Upright Vacuum - Blue Logo
516 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
