Question about Pro-Fit Pro.Fit Dg 71 01 Dodge Dakota Pickup/Durango 01 Up
2001 dodge dakota 3.9l engine code p0320 ,says ing/dist circuit malfunction. engine does not fire.it skipped than quit going down the road. about 1 hour later went back and it started up drove home, shut it off now will not start. no fire
2 Suggested Answers
SOURCE: 1993 3.9 v6 dakota, driving home and engine quit
try you plate in the dist cap
Posted on Jun 24, 2010
My 2001 dodge Dakota is running rough and the check engine light is on.
You'll have to look up the actual procedure to test the coil for code 351. The code means the computer is not able to fire the coil on demand which could be caused by several things, including a faulty computer. It could also be a problem with the wiring between the coil and the computer.
Feb 17, 2015 | Dodge Cars & Trucks
What dose the code p0320 mean on a 2001 town&country chrysler caravan
code p0320 means faults crankshaft position sensor (CKP) sensor/ engine speed (RPM) sensor ---circuit malfunction. Check Wiring---CKP/RPM and ECM engine control module
Mar 08, 2013 | Cars & Trucks
I HAVE A 97 DODGE RAM 1500 V8 AND ONE CODE CAME UP A P1391 CODE I NEED TO KNOW WHAT IT IS
P1391 DODGE - Electronic Brake control Rough Road Data Unusable/unreadable
You need to see the dealer on this, it may be programing issue.
Nov 07, 2012 | Cars & Trucks
Water getting in oil pan at front of dodge 3,9l engine.
WHEN EVER YOU WATER IN THE OIL IT'S NOT GOOD TWO POSSIBLE REASONS BAD HEAD GASKET OR BAD CYLINDER HEADS
Sep 22, 2012 | 1998 Dodge Dakota
2001 DODGE DAKOTA 3.9 AUTO 4X4 IT STARTED WHEN I DROVE TRUNK ABOUT 15-20 MILES WOULD SKIP BUCK BACKFIRE. RAN A SCANNER ON CODES P1391-REPLACED CRANKSENSOR. RAN GREAT DROVE HOME 30MILES. NEXT MORNING WAS...
Yes I have heard of it a few times on this site and it most often wiring harness related, bad branch out splices. Of course the PCM (ECM on earlier models) contains the ignition control module so it is also a suspect part.
Jan 26, 2012 | 2001 Dodge Dakota
Trouble code P0320 ignition/dist. engine speed input circuit
P0320 - Ignition / distributor engine speed circuit malfunction
The ignition engine speed sensor input signal to Powertrain Control Module (PCM) or Electronic Control Module (ECM) is continuously monitored. The test fails when the signal indicates that 2 successive erratic profile ignition pickup (PIP) pulses occurred.
Symptoms:
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- The engine may be harder to start
- The engine may stumble or stall
When is the code detected?
The P0320 code is triggered when 2 successive erratic PIP pulses are detected.
Possible Causes:
- Loose wires/connectors
- Faulty Crank Position Sensors
- Arcing secondary ignition components (coil, wires and plugs)
- Low battery charge
- Powertrain Control Module
Possible Solutions:
- Resecure loose wire or connectors
- If battery charge is low, recharge or replaced battery
- Replaced crank position sensor
- Replaced starter motor
Test it and tell us news.
Nov 18, 2010 | 2004 Ford Explorer
The time ing mark in my 1992 dodge dakota ait gone i am teying to time it right but i can not find the mark what do I do?
On a 1992 Dodge Dakota 3.9 or 5.2,there is NO Base (initial) Timing
You bring engine up on compression TDC #1
Rotate Distributor until rotor is over mark on switch plate
Back probe 5volt reference wire (Grey Wire 1992&1993--Tan/Yel 1994-1997)
Rotate Dist,back and forth,until you go from 5 volt to O volt,then lock down dist
Distributor Sensor (Hall Effect) under switch plate,is for Injector Timing, not dwell control,etc
Oct 20, 2010 | Dodge Dakota Cars & Trucks
My 1999 Dodge Dakota was going down road 70 mph quit running tried to restart firing through exhaust is it timing chain
maybe but doubt it, this sounds like lost of fuel preasure or a bad crank sensor,scan computer and see what codes are stored if any,
Jul 13, 2010 | 1998 Dodge Dakota
FORD RANGER ENGINE PROBLEM
P0320 - Ignition Engine Speed Input Circuit Malfunction - The ignition engine speed sensor input signal to PCM is continuously monitored . P0320 indicates that two successive erratic profile ignition pickup ( PIP ) pulses have occurred Some possible causes are : loose wires / connectors , arching secondary ignition components ( coil , wires , + plugs ) , on board transmitter ( 2 - way radio )
Jul 14, 2009 | 1998 Ford Ranger SuperCab
Pro-Fit Pro.Fit Dg 71 01 Dodge Dakota Pickup/Durango 01 Up Logo
364 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Ottoniel
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
