Question about Element Electronics FLX-2610 26 in. LCD HDTV
Signal keeps coming and going whether I'm using
Signal keeps "coming and going" whether I'm using HDMI or component cables with my Direct TV receiver (receiver works fine with other televisions)
    President:
  • 1,284 Answers
This is a very common issue with HDMI is compatibility. The compatibility problem is more likely the source and not the TV itself. The only work around is to use the component input as these are analog and don't have to go through basically a "handshake" as HDMI does. Please take a few moments to rate my answer. Thanks...
Posted on Nov 19, 2009
How do I connect a Sony KDL55EX620 HD TV to a stereo receiver. I am using the HDMI cable from a DirectTV receiver. How do I get the audio to my stereo?
the audio comes out of the Direct TV reciever, OR Audio OUT on the television. Some TVs that take the signal HDMI, do not put sound back out, and in that case, sound signal must come from the reciever box.
Each component, like DVD of Blu Ray will need to have a signal wired to the stereo unit.
Apr 27, 2011 | Sony KDL55EX500 55 in. HD-Ready TV
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
How do I convert from HDMI-in to Component-Out? Basically, I'd like to have my cable box (Comcast DVR) coming into the receiver using HDMI but would like to output to my TV using Component instead of HDMI....
looking at the manual here that should work for Video http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
it looks like on the receiver you would have the DVR connected via HDMI cable to the receiver On the receiver you would select this HDMI as the input. That should automatically allow that signal to be presented to the component out on the receiver you connect the cables from component out to the TV and switch the TV to select the component input -depending on the TV model this may be labeled AV1,2,3,4, etc No sound will be transferred to the TV as component is Image ONLY whats the make and model of the TV
Mar 20, 2010 | Onkyo TX-SR606 Receiver
Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Dec 30, 2009 | Denon AVR-1603 Receiver
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Element Electronics FLX-2610 26 in. LCD HDTV Logo
189 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
