Question about Delstar DS 31024 MP3 Player
PLease someone help me!
I've had mine for 3 weeks now .. and i just had to change the battery.. these are expensive batteries and they work great so finally it died.. i got another one the same one.. and i put it in.. and on the screen of my player says -starting...- and thats it.. ive tried everything to get it to turn on but it wont.. please someone help.
  • newmanba Aug 20, 2008
    I have the same problem! I just replaced the battery and now it just says starting...even when i plug it into the computer it says the same thing. i have changed the batteries many times before and this has never happened. Is there a reset button or anything?
  • amthomp25 May 11, 2010
    Well since I am having the same issue with my unit I decided to try your suggestion. I have been holding the button for over 20 mins and still have the word starting on the screen. I think someone needs to come up with a better solution for this issue. Perhaps the company needs to replace all these non working units since they all seem to be duds.
One 'AAA' is expensive, you're right. you can expect maybe ten hours of continuous operation before you have to go to the bank.
seriously, with a fresh 'AAA' battery installed, you DO have to press and hold the 'play/pause' button for what seems a long time. don't release the button until the Delstar name appears.
Posted on Jan 14, 2008
6ya staff
SOURCE:
I have new batteries two weeks old. They now will not charge properly. could it be the charger? This is on a victory 3 scooter
Did someone qualified tell you that you needed new batteries?. I would go back to the battery supplier & go from there.ALSO,if you still have the old ones can they be tested too.Ask them,i hope this helped.Colin
Sep 09, 2014 | Pride Victory 3 Wheel Mid-Size Electric...
Help! Changed battery but still don't work for a long time
you probably have a short in the amplifier under the driver's seat. I had the same problem. Bought mine used, but the amp had water damage due to the vents for it on the left side of the driver's seat letting in water, probably snow or something that fell in there. Was $1200 to replace. Basically your car will be fine for a couple weeks, maybe a month then the battery will die.
Aug 01, 2012 | 2004 Saab 9-3
2004 jeep grand cherokee laredo, po162, po123
P0123 is a TPS/Pedal Position Sensor A Circuit High Input code. P0162is an 02 Sensor Circuit Malfunctoin (Bank 2 Sensor 3) problem.
Jul 01, 2012 | 2000 Jeep Cherokee
My scale was giving me wild weights for about a week and then stopped working. I relpaced the batteries with new ones and made sure that they are both positive side up. Now scale will not turn on. I've...
Please test the sprint where compartiments batteries and clean very well with contacts cleaner contacts.
2) tIGHT THE Spring with plyer for Good contacts.
3) see if there are some wires loose positive -rED OR BLACK -negatives
Blessing
[email protected]
cell+whatsApp: +50588611441
Jan 24, 2018 | Taylor ELECTRONIC CALMAX SCALE
My HJ720IT pedometer screen is blank. I thought the battery had died but got a new battery and it still won't work.
Mine has same problem. Died a week ago. Put in new battery and it worked for a week. Now it is dead again.
Dec 23, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
I have a vxl brand new. It is set in the first 1
Your vxl is set on the wrong battery type. It got inadvertantly set to a lithium ion battery setting and it immediately reads your 8.4 volt battery as being dead! Look through your instruction manual about 4 pages in and it will show you how to set the battery setting back to a regular battery. I had the same problem and as soon as I reset the vxl motor controller back to standard battery, mine works great! Don't get discouraged, it is a great hobby and lots of fun for all. There are many upgrades you can also do by gearing down the motor for faster speed. Gear change packs are about 20.00 and can really boost your speed. I hope this helps. I am out of town but if you can't find the instructions, email me later this week and I'll see if I can find mine when I get home. Simple fix, just don't have my book on hand. [email protected]
Aug 01, 2009 | Stampede VXL Brushless RTR
C913 Kodak won't turn on
check the battery where you insert on camera kodak has an error on mine <+> should be where the <-> is and<-> should be where the<+> is
Nov 26, 2008 | Kodak EasyShare C913 Digital Camera
Ace caravan battery
Battery, if fitted is under the front LHS seat on mine
Dave.
May 13, 2008 | Car Audio & Video
Delstar DS 31024 MP3 Player Logo
47 people viewed this question
Top Delstar Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
