Question about Mercury KVM266PM-U (KVM266PMUD1600) Motherboard
Usb port problem
The problem is as follows:
If i insert any usb device to the usb ports the pc restarts.
I also inserted the usb card and tried, but the problem continued......
Thank you for rating this solution.
Posted on Mar 23, 2008
    Novelist:
  • 94 Answers
It's possible that your PC is not receiving adequate power from the power supply unit (PSU) to power everthing in use and the USB devices that you are attempting to connect. The USB port provides power as well as data connection. If you know it, what is the rating of the power supply unit in your computer?
PSU's are easy to upgrade, and some stores will let you return them if that's now what you need. (CompUSA (R.I.P.) was my favorite for troubleshooting repairs. By it, test it, bring it back if it wasn't the fix you needed.) Find someone you know/trust who know's what they're doing, or bring your CPU to a PC repair facility and let them test your computer and do the needed repair/upgrade there. Just be ready to spend a few more bucks.
Hope that helps. Let us know how you make out.
Posted on Jan 11, 2008
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Damaged USB Port
Ok I think the best method to "Fix" this would be to get your self a 4 - 5 port USB card, they are, real cheap, insert it into a spare slot, inside your PC, and install the drivers, if any, and use that one. And simply ignore the other one all together.
Feb 18, 2010 | Gateway Essential 400 PC Desktop
One of the USB devices attached to this computer has malfunctioned, etc.
This problem is caused by a USB ports of the motherboard. Try to insert the usb devices in the different usb ports and if all ports you inserted encounter the same problem then probably the ports has technical hardware problem. To solve this, buy an expansion usb card to your computer. Be sure also that the usb devices you inserted in your computer in properly working and has no defect to determine that the ports are the problem and not the devices. Please don't forget to rate me..Thanks..:-)
Oct 26, 2009 | HP LaserJet P2015 Printer
How to install drivers of pen drive
your pen drive is not recognize by the usb port onyour computer, remove the pen drive from the port and insert it to another usb port on your computer, if you still having problems, restart the computer and try again on a different port.
USB drives do not drivers for it to work.
Jul 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
Lap top and printer not cummucation
How is the printer connected to the PC, USB? Parallel? If USB, try inserting a flash drive or other USB device , to see if the port is working. If the port does not see the device, go to the control panel and remove the USB ports and restart the computer. The try your printer.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Mouse and keyboard not working / recognized by computer
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Jul 02, 2008 | E-Machines T3624 PC Desktop
Usb ports do not recognize flash drives
regisrty key maby u could try repairing your windows back it all up redo it maby sum spyware or sumthing if not bad board not powering good engh to usb
Jan 22, 2008 | Acer Aspire 3100-1405 Notebook
Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Logo
125 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
