Question about Minuteman PRO700E UPS System
The battery light came on and it started beeping. The unit has been operations 3 years. I have uplugged and reset the unit several times at different power outlets and within an hour the light and beeping returns.
    President:
  • 1,149 Answers
Hi:
I suspect you have came to the end of the battery's life in your UPS. Unfortunately, it is often about as cheap to buy another unit, instead of a replacement battery....
Posted on Nov 19, 2009
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
Chamberlain Whisper Drive 3/4 HPS Garage Door Opener beeping
Change battery , not change battery the unit will not operate if there is a power failure.backup operation. 5 years is a long time on a disposable battery.
May 11, 2017 | Chamberlain 3/4-HP Whisper Drive Plus...
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Has started to beep whenever items plugged into
If it's more than 3 years old, you probably need new batteries.
If the beep started after plugging anything additional into the UPS, you may be in an overload state, and the beep is telling you that it's choosing to beep and not function as intended rather than smoking itself. Try unplugging a piece or two from it and see if the beep goes away. If not, probably just you're batteries giving out due to old age, they'll only give you 3-5 years.
Oct 11, 2009 | Dynex Computers & Internet
It beeping all the time
Does the red light flash over the battery symbol?
If so the batterries are either faulty or have a low level of charge or the charging circuit is faulty.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
Oct 05, 2009 | MGE UPS Pulsar Ellipse Premium 800 UPS...
Keeps beeping when recharging
It sounds like you need a new battery (this is what the beeping is) even though its only a year old the battery needs replaced!
Please rate my answer and help keep this site FREE!
Thank You!
Dec 28, 2008 | Black & Decker Simple Start Car to Car...
Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Dec 01, 2007 | Scytek 2000RS-M Remote Control
Minuteman PRO700E UPS System Logo
300 people viewed this question
Top Minuteman Computers & Internet Experts
David Payne
David Payne
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
