Question about Cycling
How do I remove tire from rear to replace inner tube? It's a Centrix bike.
    President:
  • 1,137 Answers
Here is a site that has all the info you need:http://www.parktool.com/repair/byregion.asp?catid=58 Please let me know if this helps.
Posted on Nov 20, 2009
How to Replace a Blown Bike Tire Inner Tube?
unbolt wheel and using tire spoons or the handle of flat ware [as long as its strong enough to not bend ]place inbetween the tire bead and rim and pry up and over rim now either use another to pry again next to spoon or slide spoon under and slide around rim removing tire reach in and remove tube check inner tire for debris fix or replace tube install
How to change and fix flat bike tire Trek Bicycle How to Fix Flat Bike Tire
Oct 20, 2016 | Cycling
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
How to change rear tire ?
Remove rear wheel with either a 15 mm or a 17 mm wrench. Take the tire off the wheel. If you are replacing a tire, reverse procedure. If you have a flat, replace inner tube, then reverse procedure
Aug 14, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
Inner tube tire
Non-standard tube sizes drive me crazy. I did find that WalMart sells the tube on its website:
Walmart 32 Bicycle Inner Tube
This is probably your best bet, as your local bike shop may not stock this tube size because LBS bikes typically stop at 29 inch.
Feb 01, 2014 | Genesis 32" Mens Beach Cruiser Bike, Blue
I ran over a nail, and now my back tire has a slow leak, can it be repaired with a plug or does the tire need to be removed for repair? Tire has spokes.
Although most motorcycle tires can be repaired, it's a good idea for safety purposes to use an inner tube in addition to having the tire repaired. I got a nail hole in the rear tire of my 2003 Deuce and had the hole repaired and added an inner tube, and it lasted that way with NO LEAKS for nearly two years, at which point I sold the bike.
Jul 05, 2011 | 2008 Harley Davidson FXD Dyna Super Glide
Just bought bike and now the rear tire is flat, do i need to replace the inner tube or can it be fixed another way. what size tube do i need to replace it.
I recommend replacing the inner tube, the size is on your tire. I think that you should pay to have it done at a repair shop if it has gears, it will be worth it in the long run
Sep 08, 2010 | Cycling
Bike has been stored in garage for a few years (tires now have no air and gray tube is sticking out), what needs to be done before I can ride it? I don't really know that much about bikes but I don't want...
Basically check the condition of the tires, if they look dry and cracked it is better to replace them, The gray tube that is sticking out is the inner tube which holds the air for the tire. If that looks good just fill it up with air to the recommended air pressure on the side of the tire and put some light oil on the chain and the bike will be road ready. If after a few days your tires lose air again, it would be better to replace the inner tubes.
Jun 14, 2010 | Schwinn Frontier GSX Women's Mountain Bike
One of the rear tire innertubes went flat where can I find a replacement
Hi, most bicycle shops can supply replacement inner tubes for prams/joggers.
Hope that helps
May 30, 2010 | Baby Trend Expedition Double Jogger
Flat rear tire
A bike shop may be able to help you. Maybe you could just repair the tube with a tube repair kit, available anywhere bicycle accessories are sold.
May 04, 2010 | Schwinn 12" Roadster Tricycle
Air is leaking from spoke how do i stop this
Your inner tube is leaking air. Remove the wheel and remove the tire on one side only (one bead over the rim edge) to allow access to the inner tube. remove the tube and the tire the rest of the way. Basic tire removing tools are neccesary such as tire spoons and rim protectors. check the rim for sharp points as well as any debris that might have punctured the tire. Check the inside of the tire very carefully as well. If somthing punctured the tire it might be still sticking out on the inside - a potential hazard to your fingers. Patch the tube or, better yet, replace it - a much more dependable solution. Install one bead of the tire back on and then the tube. Infate and deflate the tube with one side of the tire off the rim to ensure proper fit and arrangement of the tube inside the tire. Reinstall the tire and the wheel back into the bike following manufacturers recommended procedures and torques found in a service manual.
Oct 01, 2009 | 2007 Suzuki DR-Z 400 SM
Cycling Logo
101 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
