Question about Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214T wakes up from hybernation flickering (Windows 7)
  • Samsung Master
  • 1,684 Answers
A flickering display usually indicated a failing power supply. Check out our web site at www.ccl-la.com We have a free step by step repair guide for the 214t that will show you how to open the case. Once inside look at the power supply for parts called capacitors. The tops should be perfectly flat and I would bet your have bulges which indicate they are damaged. If you find bad caps and them replace them you should be back going without any flickering. Many LCD monitors will have issues after 2-3 years of use. If you have any more questions just let us know.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 27, 2009
The backligt stay fickers contineu
Flickering or wavy picture is a very common symptom of failing capacitors in the power supply board. This is a very easy repair, it just requires replacing the 6 capacitors on the power supply board. Here is a link to a repair guide for the SyncMaster 214T which uses the same NP-20 power supply board so the repair information will be the same.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Dec 22, 2011 | Samsung 215TW SyncMaster 21" LCD Monitor
My emachine isn't starting up after hybernation, unless i press the power button and reboot. Why is this?
When your system goes to hybernation it creates a file on the root drive called hyberfil.sys in most instances this file gets corrupted and is causing the computer not to wake up from hybernation.
You would have to try and delete this file so that it will re enable the normal hybernation wake of your computer, here's how to do it:
http://helpdeskgeek.com/windows-7/windows-7-delete-hibernation-file-hiberfil-sys/
Just have to reverse the process to re-enable hybernation.
My recommendation would be to just disable Hybernation and just let the computer go to sleep if you're going to leave it idle.
Hope this helps!
Aug 03, 2011 | E-Machines eMachines Desktop PC
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
My samsung 214t becomes very blurry after startup and flickers hard than falls out.after a while (first it was after 10 minutes and then it started to take longer than a half an hour the screen became...
The flickering is caused by a power supply board that can't stabilize the output voltages. This type problem is caused by failing capacitors. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service for this model. The repair runs $30 plus shipping. You can setup the repair service at: http://www.ccl-la.com/blog/index.php/service-request-form/
CCL_Tech
Corporate Computer
www.ccl-la.com
Jun 22, 2010 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214t monitor would flicker
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
Aug 29, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung SyncMaster 214T flickers
Hi There,
I managed to fix my Samsung SyncMaster 214T from that flickering. Just changed 3 capacitors and it worked fine!!
Jun 01, 2008 | Samsung SyncMaster 214T (Silver) Monitor
214T - flickers radidly
Yes,
A flickering screen indicates the power supply is not properly filtering the output power. This happens when the capacitors on the power board start failing. Here is a link to a repair guide that shows how to dis-assemble the unit and what to look for and replace on the power supply board. The repair guide also has videos showing the process.
I hope this helps, if so please rate my solution.
BuddyMc
May 02, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
973 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
