Question about Kenmore 500 6953 Dryer
Dryer trouble dryer did not dry close and saw water on floor. this happened only one time i was wondering if this could be that my daughter overloaded the dryer thahks
  • Kenmore Master
  • 2,536 Answers
If there's water it sounds like you have a vent problem,go outside and see if air is blowing out strong and flapper is opening,dryer needs a clean out and blow out the vent line
Posted on Nov 19, 2009
My dryer is Tcm570 it started leaking water on the floor while clothes are drying, then not drying after circulation. But if I try to put it on now it turns all the power in the house off. What's
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Jan 12, 2013 | Dryers
Pump stops working during drying cycle
yes you are right it is the problem of dryer pump you have to check that pump and if neccesary replace it.
Thank you
Dec 07, 2007 | Supra SW5L30D Front Load Washer / Dryer
A loud banging noise when dryer is running. Sounds like washer does when it has an uneven load. But dryer is not even close to being overloaded. Since it is a top loader dryer and the drummer rolls shut...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 23, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Condensation is heavy in dryer, leaving a puddle of water in the bottom of the drum as well a lot of moisture on door and all over inside of drum. Happens independent of wash being done (this is a...
AC vent to close to your dryer. This is usually because your house ac is cooling the caseing of your dryer down and outside air is creeping back in thru your exhaust on your dryer. Make sure the vents are closing on the exhaust dryer air and that there is not a vent close by that is helping your dryer shell to chill. I have only seen this 3 times but it is a problem. you will notice the water after drying a load and removing it after a hour or so you open the door and there will be water. This happens only in extreme heat and usually hi humidity outside.
Aug 08, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Aspire 5610, daughter cleaned with damp cloth, monitor does not work, lights up, no graphics
That should not have happened. However, I have heard that the following solution works for cell phones dropped in water where they open it up and use a hair dryer to dry it up. Try running the hair dryer on low around the edges of the screen but not so close as to heat it up. The wiping with a damp cloth does not normally cause this, but if that is what it is then the hair dryer solution MAY work. Good luck on fixing it without having to send it in for expensive servicing.
Jan 20, 2010 | Acer Aspire 5610-4648 Notebook
Kenmore dryer doesn't recognize when the door is closed.
first try unpluging the dryer for 5 minutes and then check it,this resets the computer board just like your house computer or you could have a bad door switch or something wrong with the main board,the main board is alot more than the door switch,if you have a meter you can read out the door switch,there should be a tech sheet in the dryer maybe taped to the side wall behind the bottom panel that might help you out.
Jan 14, 2010 | Kenmore Elite HE4 Electric Dryer
I have water developing in my duct. What's going on?
I would suggest you try this simple easyfact finding venture:
remove the vent fromt he dryer(take a bucket as the vent is going to have water in it) pour the water out of the vent,leave the vent off and try drying some loads,IF the unit works as it should( normal dry times) then you will need to have the vent cleaned to the outside. many birds like to place nests in them!
Good Luck!!
Feb 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is heating, but clothes are taking too long drying -- you gave one solution already.
IF THE DRYER DRIES O.K. WITH THE EXHAUST UNHOOKED FROM THE BACK OF THE DRYER, THERE IS STILL A RESTRICTION IN THE DUCT WORK. LINT WILL BUILD UP, ESPECIALLY IF THE DUCT IS FLEX DUCT WITH THE SPIRAL LOOK. REPLACE FLEX DUCT WITH RIGID METAL DUCT WHERE POSSIBLE.
Apr 18, 2008 | Dryers
Candy CMD146 Washer/Dryer
This machine has selfcondensing system. The condense water is beeing pumped out with the cooling water. The watertap MUST be open during drying. It also may be caused of overloading. The most W/D combos is just able to dry just the half of a full load in one time.
Jan 10, 2008 | Candy CN146 Front Load Washer
My kenmore electric dryer wont heat mondel 110.86880100
I know you cleaned the lint filter so I won't even mention it:)
Is it possible that your vent hose runs along the floor (perhaps behind the dryer, or maybe even under a raised floor beneath your dryer - as mine used to) before going up and out to the outside vent? If so it could be that water has seeped in through the vent opening from outside and become trapped in the hose and is acting like a drain trap and blocking moist air from escaping which is causing the clothes not to dry.
This is what happened to mine once anyway. A cracked vent flap was all it took for the water to build up over time. Unfortunately mine ran under the floor and I had to actually tear up my floor in order to remove the water without having it flow all over my house. Fixed the drying problem though (and a new vent flap insured that it didn't happen again).
Jan 05, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 500 6953 Dryer Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
