Question about Microwave Ovens
Hi: I have a kitchen aid dishwasher. After it finishes cleaning, many of my cups have specks of dirt on them. My handy man said that it was because the thing that grinds the dirt is not working properly. We took the dishwasher out from the inside, it below the trays where the dishes are placed, but could not find the grinder. 1) Is this the cause of the problem? 2) If so, how do I fix it? Thanks
  • 10,515 Answers
Water-inlet valve
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Continued__________________________________
Posted on Nov 19, 2009
  • taran_2005
    taran_2005 Nov 19, 2009
    Cont______________________________________
    Internal filters
    Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
    Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
    Some
    have filters in the bottom of the dishwasher that you need to
    periodically clean. You don't need any tools to remove the filter, and
    cleaning it is easy. Consult your owner's manual to determine which
    type you have and its maintenance requirements.
    If your filter is clogged, it may be causing the cleaning problem.
    Drain valve
    Some
    dishwashers have a valve (or gate) that should open only during
    draining. If debris lodges in the valve, it can't close properly, so
    water drains out during the wash cycle. Most dishwashers drain into the
    garbage disposer. If yours does that, listen for water flowing into the
    disposer during the wash cycle. If you can hear it then, the drain
    valve may be clogged.
    Spray arms
    There's
    a spray arm at the bottom of your dishwasher--it may have a tall spray
    tube mounted to the center of it. There may also be a spray arm located
    directly beneath the upper rack of dishes and/or above the upper rack.
    If
    debris is blocking the holes in the spray arms where the water comes
    out, it could cause cleaning problems. Regularly inspect each of the
    spray arms and clean out the holes as necessary.
    Water temperature
    To
    get the best cleaning results, the water entering your dishwasher needs
    to be hot enough. Try running the hot water in your kitchen sink for
    about 30 seconds before starting the dishwasher, to pre-heat it. Also,
    if your dishwasher lets you select a higher wash or rinse temperature,
    try that to see if it helps.
    To
    check the temperature of the hot water that comes from your kitchen
    faucet use a waterproof thermometer. If the water isn't 120 degrees
    Fahrenheit, your dishwasher may have trouble getting your dishes clean.
    You could increase the temperature of the hot water to the whole
    house--and therefore the dishwasher--by adjusting the hot water heater
    thermostat.
    Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
    Detergent cup
    Dishwashers
    don't perform their best if detergent is introduced only at the
    beginning of a cycle, so add detergent to both parts of the cup.
    Let me know, if needed further assistance.
    Hope i helped you.
    Thanks!!
Kitchen Aid microwave KHMS105EWH-0: I started to heat a cup of coffee, it momentarily interrupted power to the kitchen, fluorescent lamps went out, then slowly came back on. More below.
Because of the loud snap you are hearing, my guess is you have something shorting out in the high voltage section of the microwave. I'm surprised it is not blowing the internal microwave fuse yet. Average repair cost depending of what part it going bad is approximately $150 to $200. Considering the age of your micro my suggestion is put the money towards a new one.
Mar 01, 2015 | In Microwave Ovens
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
Jan 23, 2012 | Microwave Ovens
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My kitchen aid microwave makes a loud crackling noise every once in awhild
Is it a carousel (turning platter)? if it is, than it is probably dirt on the platter support wheels and the platter support groove/track on the bottom of the oven, clean the glass plate, the support wheels, and the bottom groove as well, if you want to make sure the crackling comes from the carousel system, take it all out (support and platter) than place a glass of water in the oven and start it, if there are no crackling noise than my theory is correct, if the noise is still there than have it checked by a professional technician...
Sep 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Not cleaning dishes on bottom even when half empty - leaving film. using rinse aid. ran two cycles with vinegar help
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 04, 2011 | Microwave Ovens
Dosent rinse always dirt left in cups
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 23, 2011 | Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
    Dishwasher Spray Arms not Spinning
    How to Buy Appliance Parts Online
    Dishwasher Problems The Heating Element not Working
    heatman101
    Asker
    Sep 30, 2010 | Microwave Ovens
    The burners on the kitchen aid superba range work, but the oven doesn't?
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
    Oven Problems Replacing the Igniter
    http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
    heatman101
    Aug 19, 2010 | KitchenAid Microwave Ovens
    Hi we have just purchase a seal for our stove how do we go about putting it in my husband is a handy man an I sure could do job
    He should disassemble the door to remove the bad seal, and reverse the procedure to install the new seal. A handy man should understand.
    Sep 16, 2009 | Microwave Ovens
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
