How can i use my digilogic lcd tv as a computer monitor? it has the connections as my current monitor but when i connect the tv to the computer there is no picture,the computer base is recogniseing the tv as when i replace the tv with my old monitor the pictures and words are all large,so the computer has reset itself to be compatable with tv,can anyone help?
    Problem Solver:
  • 12 Answers
Have you checked the menu set-up option on the TV set ? Your computer may be sending an out of range signal, so set it to low resolution and try that. Obvious other thing is the "input" setting, it may not auto detect it.
Posted on Nov 19, 2009
How to connect 4 x HPL1706 monitors to a TV or PC/Laptop?
Did you try using a "Y" adapter cable. That would allow you to connect to two devices.
Mar 25, 2015 | HP L1706 17" LCD Monitor
How do i change speakers
There are couple of questions to ask , are u trying to connect the speakers to the monitor for a tv connection or using it to connect to a computer system , if connecting to the computer system , the audio settings have to be changed to the current speakers you connect to the monitor , or there might be a up link cable u might have got when u bought the monitor using which the sound will come out .
Dec 14, 2014 | LG FLATRON M237WD 23 inch LCD Monitor
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
Aug 30, 2011 | HP Pavilion a420n PC Desktop
I connected va1913w monitor but can not find where to connect speakers
Look for the green mimi phone jack on the back to connect the cable to the PC AUDIO LINE OUT.
See page 9 of the user manual here: http://www.viewsoniceurope.com/ru/assets/040/11346.pdf
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 06, 2011 | ViewSonic VA1913w Monitor
My viewsonic LCD monitor is going pink for every 10-15 minutes.
The video cable'pins and connections are nice and tight at both ends? Try it with another PC to make sure it is not the PC video card problem.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Dec 28, 2010 | ViewSonic VA1930WM LCD Monitor
Connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Jan 28, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
