Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
My waste disposal unit wont turn on
MY waste disposal unit make ''In sink erator model 65'' got something caught in it so I took it off got the thing caught out. now it will not work at. do I need to reset it some how
  • 82 Answers
The reset button is on the bottom, not side.
Posted on Nov 27, 2009
  • 863 Answers
Theres a reset button on the side of the thing.  Also check the breaker box to see if the switch got flipped.
Posted on Nov 19, 2009
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
Dec 04, 2015 | Garbage Disposals
Can my Garbage disposal be fixed
Where exactly is it leaking? Is it leaking out of the bottom of the unit?
Jul 18, 2014 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
Mar 23, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
In Sink Erator leaks half way down
1) Copy following link for troubleshoot and replacement tips.
2) Insinkerator usually has 5 year warranty.
If unit is leaking, then replace with new disposal.
Waste King disposals have longer warranty, but local hardware sells Insinkerator/Badger for less.
Jan 18, 2013 | Electrical Supplies
A small screw is lodged in my in sink era tor (1/3horse power) disposal. I have tried to move it with a long mechanic file and it will not budge. I can see it but I cannot get it with long needle nose...
you can remove the whole unit ,and take off the black rubber gasket and you can get your hand in side,or you can try toturn the blades with the disposal allen key,that it comes with,insert in the bottom of the unit and turn it each way or remove the trap and waste arm from the disposal,you might be able to pop the item up and loose it so you can
Apr 19, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
In sink erator( 5 horsepower) doesnot function
On the bottom of the disposal is a place for an allen wrench. Take and turn the unit with the allen wrench to break it loose. It sounds as if has something sticking the blades.
Jun 03, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Badger disposal keeps turning off after about a minute
unplug the unit from the wall.take a strong flash light look into the unit. there is something in there.the braker shut-down only when the motor is over loasded. meaning, there is something holding the blade.
Jun 01, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Jammed disposal (in sink erator) i believe a nail was lodged there. it came out but it still doesn't work. Had a allens wrench and hit red button and it still doesn't work
My unit was not spinning, seemed like no power after it would just sit there and make that humming noise. Used the wrench to loosen up (if any) debris. I didn't realize the little red reset switch on the bottom was not popping out all the way. After the wrench, I then depressed the red button and it worked fine. I would check to make sure your switch is out all the way before trying other solutions.
Jul 04, 2008 | Dishwashers
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
415 people viewed this question
Top Buck Home Experts
Gene Haynes
salaberrios
salaberrios
Level 1 Expert
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
