Question about RSQ E500 DVD Player
Wiring diagram for rs torquemaster inverter 266-890
I dont no how to wire my phase inverter
What causes a red light on an TB Wood Etrac XFC 1001 inverter and the motor will not start Is there an internal fuse Do I need 3 phase for the input
Is that red light flashing or continous lighting? You do not need 3 phase input for that model. Do you have the input wiring diagram? If the red light is flashing maybe the emergency stop input is active. If the red light is on continously then it maybe in stop mode or torque limit, ask electrician to check the wiring.
Dec 31, 2016 | Inverter Electronics - Others
Wire diagram to change a royal sun tan bed model # 46/6 vhr*turbo 1100 from 1 phase to 3 phase
send me your email address and I will give you what I have. We have a 2004 model 46/6 turbo. Wiring diagram is in the manual. I have this.
Jul 26, 2012 | Cars & Trucks
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
Defrost timer wiring diagrams show below:
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I have a WESTINGHOUSE WELDER type rs 250 that is wired for 440 volt and need to change to 220 volt.
HI:) If that is a 3 phase 440 volt and you want it to use 220 volt 1 Phase you will have to get a phase inverter to change it from a 3 phase to a single phase.
Dec 19, 2010 | Welding Tools
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
How do I wire a three phase electric motor to 110 plug
You can't run a 3-phase motor on 110V unless you use a 3-phase inverter. Depending on the size of your motor, these will probably run you around $150 for the least expensive type. Take a look at---
Jul 24, 2010 | Electric 1HP Century Single Phase Extra...
Yamaha RS 100 wiring diagram
Hi, Randy for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Motorcycle Wiring Diagrams
Yamaha RS 100 wiring diagram Google Search
Yamaha RX 100 Workshop Manual
Yamaha Rs100 1975 Usa parts lists
Yamaha RS 100 Manuals Support and Troubleshooting
Dec 10, 2009 | Yamaha Motorcycles
I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Nov 03, 2009 | Kitchen Appliances - Others
RSQ E500 DVD Player Logo
137 people viewed this question
Top RSQ Televison & Video Experts
Are you a RSQ Televison and Video Expert? Answer questions, earn points and help others
