Question about Samsung HT-P38 System
Video inputs I've tried hooking up my Nintendo Wii though my ht-p38 and i get audio and but no video!!!  Any help would be great
I had the same problem until I switched my player-to-TV connection from S-Video to Composite.  Then it worked just fine.  Now I have player-to-TV as Composite, and Wii-to-player as Composite connected to Aux1.
Posted on May 12, 2008
I just bought a wii and I'm hooking it up to an older model tv. the inputs are on the front and there is only one audio input and one video input. I plug in the red cable in audio and I hear the music...
The yellow cable needs to go to video.The red and white are left and right speakers or stereo.Usually there is a yellow for video,the cable doesnt have to be yellow, another red or white will work.It just needs to be in the video jack or output.
You need one more cable for video.Also be sure your tv is set to the correct input for the wii to work.Possibly it may need to be on channel 3 or 4. Or if the tv is newer try component or any input available in the tvs setup menu.
Aug 23, 2011 | Nintendo Wii Console
When I turn on my Wii the led light is green, but the screen in black and I can hear the sound.
make sure the video cable is plugged into the correct input and that there is no cuts or crimps in the video cable. Also try a different video input. As sometimes a tv will have s-video input and a rca input and if you dont have it in the selected video input it might not display.
but because you have audio i am confident that your problem lies in the video input not being properly plugged in/selected or the cable is bad.
So try a input that you know works and turn off the wii then unplug the video/audio cable from the wii and plug it back in.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Nintendo Wii Console
How can i connect Nintendo wii to avr-590. Have
To connect a Nintendo Wii to an AVR-590, I am assuming this is a Denon Receiver, you will need to connect the Nintendo Wii to the TV, then connect audio out from the TV to the AVR-590 Receiver, and select the receiver to be in Pro Logic. Depending on the TV, if you have fiberoptic output on the TV, you would hook a fiberoptic out from the TV to the AV Receiver, but you will still not get true Dolby Digital, just Dolby Pro Logic. This will be the most effective way to solve the problem. Hope This Helps
Geek Squad
Dec 28, 2009 | Electronics - Others
I plugged the red,white, yellow audio/video cables into the front jacks on my Sony Vega. They are marked input 2. When I turn the TV to all inputs, including input 2, I just get the black screen. When I...
Sounds like you have the Wii hooked up properly. I would suggest trying the other inputs on the TV just to be sure input 2 isn't faulty.
After trying the other inputs if the Wii still won't show any video then try another set of cables and after that if the video can't come up then the Output from the Wii is bad and the main board would have to be replaced.
Dec 02, 2009 | Nintendo Wii Console
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
I have the HT-S3100 model, and hooked up my tv, xbox360, and Wii to it. The audio works for all three, but the only video I can get is for the xbox. I am using the component hookup and it is hooked up...
On all tv's there should be independent input for all devices. Xbox 360 ,Wii, and tv. Take a look at input at the back of tv. The Xbox input should coincide audio/video. The same with each device. Then you use the tv's remote to select the input for each device. They should all work independently from each other. Such as component 1 for Xbox, component 2 for Wii, and depending on what type of tv input you use, such as coaxial, RCA, you note and put tv input setting on the device that you are going to use. If you have the audio working on each device, check the video input for each device. Make sure they correspond.
Oct 13, 2008 | Onkyo Audio Players & Recorders
Wii Start but the game didn't start, screen went black
  • Is this your first time hooking up the Wii console or have you moved it to another TV or VCR?
  • The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
    • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
    • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
    • Look for inputs marked Audio and Video IN.
    • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
    • Do NOT connect your system to anything marked OUT.
  • My experience shows that the majority of these issues can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
  • If you have verified the connection is correct, and are still receiving a blank white or blank dark screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired.
Jul 11, 2008 | Nintendo Wii Console
WII Video doesn't show up with my receiver
Make sure that you have the reciever in the correct setting.  Sometimes on them the s-vid is like video 3 or so on
Oct 12, 2007 | Nintendo Wii Console
Samsung HT-P38 System Logo
237 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
