Adding Second Hard Drive to Gateway NV7802 laptop
I have a Gateway NV7802 laptop. Want to add a second hard drive in the available bay below the memory. Can't figure out how to insert it into the black plastic piece.
  • 1 more comment
  • jorwig Nov 21, 2009
    How do I post a picture? Also how do I reply to a "solution"?
    It is a Gateway NV7802 laptop; came out only a few weeks ago in the Windows7 release.
    I am talking about adding a second hard drive not replacing the primary. Several other users have said they added the hard drive from their older laptop into this second slot. It is inside the case. If you read the reviews on Best Buy you will see comments about the second hard drive plus someone posted a picture.
    I did contact Gateway first and they said they couldn't/wouldn't help install a "third party" drive into the unit.
    Based on the Best Buy reviews, I know that several people have done it and they gave no indication that it was a big deal.
    Can I send pictures of the inside of the laptop?
    Genius:
  • 1,112 Answers
Hello Jorwig: If you can send me pictures of the install bay for you laptop i would be more then happy to assist you in install the drive. Also make sure you don't need a harddrive caddy for this second drive. But most harddrives are mounted from the bottom with four screws holding the unit in place. But i need to see pictures of the unit first to assist you more. Send pictures to Delhielectronics@live.com
Posted on Nov 22, 2009
  • 4,472 Answers
I have read both manuals available from Gateway and neither one has any direction at all! I am going to call gateway myself on monday, just because this is pretty ridiculous. How would the average user ever figure it out. They don't even show a picture of the bottom without the covers on or any explanation. It is pretty self explanatory job if you've done it enough. Once monday comes around I will call them myself. I would suggest you contact them as well. They will be able to give you step by step directions.
http://support.gateway.com/support/?cmpid=topnav
Thank you,
Lee
Posted on Nov 21, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Before you start the procedure to install another hard drive, shut down the computer and unplug the power cord and all other cords running from computer's case. You will also need to unplug any network cables or telephone lines. Lay down a towel, and Place your computer on a flat and level surface at a comfortable height. Make sure that the surface is very sturdy and will support the weight of the computer easily. Remove the thumbscrews from the rear of your computer's casing. Gateway desktop computers use large thumbscrews that are easy to grasp and turn, without the aid of tools. Remove the side of the computer tower and set it aside. Lay your tower down so the open side of the computer is facing upward. Shine your light into your computer case, so you can easily see the slot for hard drive. Typically, on Gateway systems, the hard drive is located on the front of your case, directly behind the air vents. Pull the hard drive bay out of the computer and place the additional hard drive into the bay, and screw the hard drive in. Once you have both screws tightened, replace the hard drive bay into your tower case, and reattach the screw that holds the drive bay to the case. Replace the side of your case and reattach the thumbscrews. Reattach your cables for your monitor, keyboard, mouse, and speakers. Also reattach your phone and/or network cables as well.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dell inspiron 3847
Dell has not published the procedures for installing an additional SATA hard drive, the Inspiron 3847 has a second 3.5" bay, for the second hard drive next to the primary hard drive, there should be a set of rails located in the bay, two 6-32X1/4, phillips head screws are needed, to attach the rails.
The procedures on pages 26 to 28 of the owners manual should give you an idea of what is required for the installation.
http://ftp.dell.com/Manuals/all-products-Infodev/esuprt_desktop/esuprt_inspiron_desktop/inspiron-3847-desktop_Owner%27s%20Manual_en-us.pdf
You will need a SATA data cable there should be a spare SATA power connector inside the case.
After installing the drive enter the system setup and check that the hard drive is 'enabled' [on] and recognized.
For Windows to recognize the second hard drive, it must be partitioned and formatted.
Go to Control Panel, Administrative Tools, Computer Management, Storage, Disk Management, right click new drive, select format, then you can assign a drive letter.
May 08, 2014 | Dell Computers & Internet
Hard drive bay opening
Take the screws out of the panel labeled 3. You'll find the hard drive in there. Usually, the drive will be secured with 2 or 3 screws - undo those and slide it out to remove/replace. I tried to look for a service manual but no dice. Best of luck!
Feb 04, 2014 | Gateway NV77H19U Laptops
Add second hard drive
There are three variants for this case: the mini-tower (which you say you don't have), the "Small Form Factor", and the "Ultra-Slim Desktop".
The "Small FOrm Factor" has an internal 3.5" bay that will support a second HDD.
Dec 10, 2013 | HP Compaq dc7100 PC Desktop
I WANT TO ADD A SECOND HARD DRIVE WHAT WOULD BE THE PART NUMBER FOR THE CADDY.. AND ALSO UP TO WHAT SIZE HARD DRIVE CAN I ADD
The only practical way to add a second hard drive to the dv9720us is to use an external USB unit. There is no provision for a second internal hard drive (standard for laptops). The "expansion port" is simply another wire connection to the motherboard's data bus, and requires a proprietary cable from HP. Using a USB external drive is a standard approach and does not require any special drivers, etc.
There are a number of good external hard drives w/USB connection available from Costco, WalMart, KMart, and other retailers. HP prefers Western Digital (as do I, from years of repair experience...they last longer), but there are a number of decent brands. You can use any size you want. 1TB drives are not uncommon today. Prices generally range from a little under $100 to around $200 for large capacity drives.
Hope that's helpful.
Jan 01, 2011 | HP Pavilion dv9720us Notebook
I want to add second hard drive to gateway 700X. what is the maximum size and RPM that the 700X can handle?
Your computer was most likely built circa 2002 so there is no limit on the capacity of the hard drive. As far as speed, the 7200 rpm hard drives are plentiful. I usually get my hardware at www.newegg.com they have very competetive prices and ship fast...their website is easy to navigate for searches and they offer open box deals and free shipping. You should have at least 2 empty 3.5" bays to place a second drive, so go with any capacity you can afford.
Jun 26, 2010 | Gateway 700 X PC Desktop
What do i need to install a WD Scorpio Blue 500Gb hard drive in my HP dv90052us laptop - i've got the drive but it does not fit in it's slot like the original drive does - i'm putting it in the second...
You may need a "caddy" -- a metal shell that wraps around the disk-drive, in order to line-up its "data" and "power" connectors with the matching "sockets" inside the second drive-bay.
Order the caddy from http://support.hp.com
Apr 18, 2010 | HP Pavilion dv9005us Notebook
Gateway w650i Physically removing a hard drive my laptop help
I ran into this same problem on the exact model laptop. The solution is to remove the two screws that are in the laptop hard drive on the right... Those are obvious... The next step is to remove the two little white space fillers that are to the left of the laptop hard drive on the furthest side from where you removed the screws. That allowed the entire hard drive to now slide to the left toward where those place/space holders were. (don't lose those white pieces) Once you have the hard drive slide all the way left away from the connectors that were holding it in place you can slide up one side of the Hard Drive and easily pull it out!
Apr 08, 2010 | Gateway Computers & Internet
Does the toshiba satellite a135 s2276 accomodate a second hard drive?
You won't find internal room to place a second hard drive, if that's what you're asking. Most laptops simply do not have the internal space, especially thin-line units.
What you could do for extra storage space is purchase an external drive.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Steps to add new hard drive to my dell dimension 2300
YOu can refer to this site..they are all the same procedure in adding hard drive in a computer.
http://www.infohq.com/Computer/adding-second-hard-drive-review.htm
melnavz
Nov 10, 2008 | Dell Dimension 2300 PC Desktop
Sata drive will not fit
This is clear that your laptop doesnt support SATA and will support only to the previously used type of HDD..
Thankyou
Jun 17, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
536 people viewed this question
David Payne
David Payne
