Question about Maytag ZigZagW / B Side by Side Refrigerator
MAYTAG ZIG-ZAG FRIDGE-FREEZER WANT DISPENSE WATER
When trying to dispense water,with water selected ice trys to come out but flap dosen't open so ice gets stuck too. Only wants to dispense ice cubes ,wether on water ,crushed or cubed
  • Maytag Master
  • 4,654 Answers
Sounds tome that there is a short in the dispenser control circuit, keyboard or Control Board. If you had the model number I could help you better than this. I possibly would be able to walk you through this, Let me know, Sea Breeze
Posted on Nov 19, 2009
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Maytag MSD2574VEM00 refrigerator - ice does not stop dispensing.
Check to see if there is a lock button that will stop the ice from comming out then check the pad that you push on to get the ice and see if its stuck in , there is a switch behind the pad and it will need to be replaced
Jan 18, 2014 | Maytag MSD2756G Side by Side Refrigerator
My Maytag msd2556ae will not dispense water throught the door. It makes ice just fine, and will dispense ice through the door, but not water. I've replaced the filter in the fridge, but no change.
There could be a blockage of its iced up. A complete defrost might fix it.
you'll have to leave it switched off with the doors open for 24 hrs.
Sep 01, 2012 | Maytag Refrigerators
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
GENE
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Does not dispense water or ice.
Replaced the main electronic board at the back of the fridge. Works fine now.
Jan 16, 2009 | Refrigerators
Ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it.
2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag ZigZagW / B Side by Side Refrigerator Logo
383 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
