Question about Lexmark Wheelwriter 35 Series II Typewriter
How do you save margins and save information to print out later on IBM wheelwriter 35 by LexMark?
  • Lexmark Master
  • 3,594 Answers
First thing is to be sure the batteries are good and the holder is clean. If there not you will get lo batt on the display and everything you put in will clear when you turn it off.
To save something Press store and an address 01-99 type info when done press store again info. is stored. to print press play and the address. To delete use del and the address.
DickyO
Posted on Nov 19, 2009
IBM 1500 Typewriter has started beeping once when I reach 35 on the 10 pitch scale. I have reset my margins and cleared all tabs but it still does it. It just started do it.
Have you replaced the batteries in the machine? Lift the cover and you should see a holder that usually has 3 AA batteries. You can replace them with the machine turned on. Once they are replaced, turn the machine off for a few seconds and then turn it back on. Change the margins and see if that works.
Jan 07, 2016 | IBM Wheelwriter 1500 by Lexmark Electronic...
Unable to set right margen
The typewriter will type thru the right margin it simply beeps when you get near it
Jan 01, 2015 | IBM Lexmark Personal Wheelwriter 2...
Change left margin on IBM wheelwriter 2000
To change the left margin, hit the return button which will take you to the left margin. Hit the margin release lever (mar rel) and then the backspace button to go farther to the left and stop where you want the margin to be. Hit left margin and that is where it will then be set.
May 09, 2014 | Lexmark Wheelwriter 3 Typewriter
How do I re-set the right margin for a IBM Wheelwriter 3500 Lexmark?
Go to the R. margin, press and release mar rel key, space to desired location press R. mar key.
DickyO
Mar 16, 2011 | Lexmark Wheelwriter 3500 Typewriter
Ibm wheelwriter 35 typewriter user manual
Go to lexmark.com & click your way to publications you can print one out from there.
DickyO
Jul 15, 2009 | Lexmark Wheelwriter 35 Series II...
IBM personal Wheelwriter 2 margins not clearing
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Jun 24, 2009 | Lexmark Wheelwriter 5 Series II Typewriter
Need to reset all the margins on IBM Wheelwriter 10 Series II. The margin release button will not release the left margin.
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
DicktO
Jan 15, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 won't let us clear the left margin
If the carrier (print head) goes to the left when you turn the T/W on then try this.
Return to the L. margin, press mar rel key, backspace to the location that you want the margin, press L. mar key the wheel should spin and reset the margin.
DickyO
Oct 16, 2008 | IBM Wheelwriter 30 Typewriter
MANUEL
The l. row of keys say save play and delete, hold the save and press 01 to 99 as an address release and type when finished press save again, To play use the same procedure with the play key.
DickyO
Jun 05, 2008 | Lexmark Wheelwriter 3500 Typewriter
Lexmark Wheelwriter 35 Series II Typewriter Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
