Question about Dryers
Microwave suddenly died in the middle of cooking
2008 microwave suddenly died in the middle of a 2 minute cooking cycle
  • Gerry Harvey
    Gerry Harvey May 11, 2010
    Check plug fuse just in case...
    Scholar:
  • 124 Answers
The only 2 user replacable parts in a microwave are the lightbulb,
and the 20 amp ceramic fuse. if you have checked the power cord outlet it's pluged into and both are fine. It's possabbe the fuse behind the controls is bad. Theese fuses look the old car fuses only
not made of glass they use white ceramic. A philips screwdriver will normally remove the outer shell of the microwave make shure it's not plugged in! After removing the outer shell look behind the controls on one of the power lines there will be a snap in fuse the above mentioned removal is easy it will pop right out replacment is oppsite of removal. If the fuse is bad replacing it cost about $3
warning don't mess with any thing else if you do this!!! microwaves contain radioactive meteral If you don't think you can do it safely take it to a pro or buy a new one
Hope This Helps gota lot of good years out of microwaves by changing those fuses. Most people just throw them away microwaves that is
If this helps ya
please leave feedback
Posted on Nov 19, 2009
None of the buttons are working; unplugged and
Depending on the model its down to the keypad
Feb 12, 2010 | Panasonic Microwave Ovens
Oven will not cook. turntable and fan will not operate, but light, timers controls all appear to operate. checked door seal and allignment and appear to be ok. oven is 4 days old. it stopped operating...
its a defective lower door interlock switch or a faulty relay or triac. First try again a pick up a little or push down a little on the door and see if it will work
Sep 12, 2009 | Haier MWM10100SS Microwave Oven
Not cooking food even though it comes on
Check the power setting. You can tell if it is on a lower setting because it will cycle ( you can hear it humm lower for a short time then the sound is different and then it humms the same again. It happens...it is new.
Sep 02, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
When microwave was on I heard a loud bang and then it stopped.
could have blown a fuse inside the unit or mine sometimes trips the breaker
Jun 01, 2009 | Emerson MW8777W Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
I have a recently purchased microwave since CHristmas. It was working wonderfully. Recently, I moved and plugged the microwave back in. THe light is on but will not program anything. I tried to plug into...
We have the same model. It's a piece of garbage. I loved the retro oval window and all and the size was perfect for our space. Then, the paint started chipping off the inside front, the timer started working intermittently, and the oven would just quit in the middle of the cooking cycle! Today, it finally just up and died. I unplugged and replugged it. No go. Finished cooking on stove top. My suggestion? Do like we're going to do and go buy another microwave...not another GE!
Good luck! Peacenikkie@charter.net
Jul 06, 2008 | Microwave Ovens
Shuts off after cooking a few minutes
Since it's under warranty, I would check with MayTag or a local Maytag-authorized servider: http://maytag.com/support/service_parts.jsp
Apr 23, 2007 | Maytag MMV1153A Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Dryers Logo
87 people viewed this question
Top Dryers Experts
