Question about LG VERIZON VX3200 Cellular Phone
I have a Verizon Wireless Blitz and the display screen just stopped working today. Its only 6 months old. Help!!!
I dropped it and now it won't turn on
it could also be loose wiring after you have dropped it, either way someone definitely needs to open it up and take a look
Apr 27, 2014 | Verizon Wireless PCD Blitz TXT8010 -...
My Verizon Blitz won't connect to my computer
Endless hours were spent trying to connect my Motorola Razr to my computer. This finally worked:
Go to Google Playstore on the phone. Download Motorola PIM (all upper case).
If you have an extended battery case/charger on the phone, remove the phone and insert the USB cable into the port on the top of the phone.
Or
Download "Airdroid" and connect wirelessly.
Nov 02, 2013 | Verizon Wireless PCD Blitz TXT8010 -...
I plugged in my phone but it will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 04, 2012 | Verizon Wireless PCD Blitz TXT8010 -...
I can't get into phone
##33284+send=Debug Mode
##3328873+send=feature menu
##7764726+send=program mode
##2773+end=diagnostics screen
##7738+end=change p_Rev
##2240+end=more S/W test
##4771+end=free gps
#5625*+end=reveals unlock code
##667899+end=mms test mode
#4357*+end=help
#46484258# factory test mode
*#6870 + END=MTP MODE Off
*#6871 + END=MTP MODE On
*#7678 + END=MTP Menu
here this might help I tested all these codes myself on verizon blitz every one works
Apr 01, 2009 | UTStarcom Blitz Cell Phone
LG Voyager won't reboot
Interesting, normally the screen only appears with water damage, which I am sure Verizons customer service has continued to tell you that is the cause without thinking the customer might not know for themselves, The only way to fix this is to got to a Verizon Wireless store and ask them to do what is called a software flash, now it may delete all your information on your device but at least it will work, if you need any more help with this let me know.
Jan 02, 2009 | LG VOYAGER VX10000 Cellular Phone
LG VERIZON VX3200 Cellular Phone Logo
118 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
