My shredder won't continuously shred a piece of paper. I have to reverse it then turn it on again multiple times to shred just one piece of paper. Can I fix this?
    Genius:
  • 1,218 Answers
If it is a x-cut shredder try oiling ( with a lightweight shredder oil ) onto a sheet of paper then shredding the sheet of paper to get the oil down into the cutting teeth....also try cleaning the "eyes" which are in the middle were you insert the paper..( they may be dirty.)
Posted on Aug 29, 2010
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
My royal shredder js1100 will only shred in reverse.
Simple to solve!
Get some longnose pliers or strong tweezers.
Unplug the beast. You do not want to shred your finger nails, or your fingers.
Flip the mechanical part upside down. You will find small pieces of papers near the rollers. Pull them out with tweezers or pliers.
Keep hands out of harm\'s way, plug shredder and make it run in reverse for 1/10 of a second.
Unplug and remove more paper impacted in between rollers.
Repeat last two steps until no paper is seen by the rollers.
Plug and continue shredding your papers
Piece of advice. Do not shred your credit cards in shredder. Scissors are cheaper and do not mess your shredder!
Jan 15, 2014 | Office Equipment & Supplies
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Machine won't shred. Does turn on, and goes in
You dont say make or model so...get some shredder oil into the cutting teeth where you insert the paper...especially if its a x-cut shredder..make sure once in a while you shred a piece of paper with some of the oil poured onto the paper for lubrication of the cutting blades.
Mar 04, 2010 | Office Equipment & Supplies
Fellowes 3011001 shredder stopped shredding. tried to remove shredded pieces but could not.
First, try switching to reverse, alot of times, stuck paper will come back out in reverse. Then unplug the unit, turn the head upside down and with a small flathead screwdriver, knife, or tweezers, dig out pieces of paper. It takes alot of effort but by digging small pieces out, a little at a time, you can get most of the paper free.
Nov 15, 2009 | Fellowes 3011001 Shredder
Shredder runs in reverse only can u help?
make sure your paper sensor detector is clean....If so, you probably have a bade sensor...
Mar 30, 2008 | Fellowes P700-2 Shredder
Shredding stops after 2 or 3 inches
If you have a strip cut machine it may be a problem with the gears. if it is not a strip cut it may be overheating due to not being oiled. First check with your manual to make sure you are not exceeding your duty cycle some machines only have a 2min on and 10 min off cycle,
Oct 20, 2007 | Fellowes P70CM Shredder
270 people viewed this question
jasbo
jasbo
