Question about Raymond Weil Parsifal W1 watch
Removing links from stainless steel Cartier Argent watch
The band does not have visible pins as in most bracelet watches. The only thing that looks like a possiblity is a hole in the underside of the bracelet that touches the wrist. I have tried sticking watch pin removers in the hole but do not get any movement of the link. These holes are three in no. on three links on either side to the closure. This is a replica watch I believe based on the upscale Cartier Santos. Any suggestions?
  • 1 more comment
  • syd9 Jan 16, 2008
    I am the one who posted this message on Jan 11,2008. I, after tinkering with the band, have found the solution. The holes, as mentioned, are the access points to removing the links. First, you will need a very thin slot head screwdriver. After inserting the screwdriver turn slightly which will disengage a nipple-like metal piece that fits into the link next to it. Second, WHILE doing this try moving the link either up or down. The procedure just mentioned might take several trys but don't give up. To re-install a link slide it back up on the guide that is there until you "JUST" reach the nipple. Depress the nipple until the link passes it and the link with then snap into place. Hope this helps.
  • jocdoc184 Nov 30, 2008
    Help me to remove links so that it fits my wrist.
    Thanks
  • andykcole Feb 11, 2009
    I have a Gents 18k pink gold Datejust 1601 from 1970s.. the 18k Jubilee Bracelet needs an extra link but there are no pins or screws visible on any of them..?
    I have been told that it is possible to add or remove links using a special tool..
    I wonder if anyon has heard of this
SOURCE: cartier santos links
The links of this watch require special tools and expertise.it's not like a seiko. you should take it to a cartier jeweler I don't think they would even charge you for that.
Posted on Oct 01, 2007
  • 93 Answers
SOURCE: i have a cartier santos wrist watch every time i
It sounds like your watch is in need of service. A qualified watchmaker can service your watch for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Posted on Apr 16, 2010
SOURCE: I have a 7 year old Raymond Weil Women's Parsifal
If you are talking about the bezel, which is the bit on the outside of the watch, you should contact the Raymond Weil repair centre SWICO. They repaired my Othello when half the bezel fell off. They had it back to me in no time! Their details are on the Raymond Weil website:
http://www.raymondweiluk.co.uk/t-faq.aspx
Good luck
Posted on May 12, 2010
escapement
  • 2334 Answers
SOURCE: My Cartier Santos Stainless/gold Screws watch band
Only CARTIER itself will solve it. There is no way you can repair it outside CARTIER. Contact CARTIER and ask what the cost would be. Be prepaired to pay a lot.
Posted on May 19, 2010
mcdevito75
  • 1970 Answers
SOURCE: Is my cartier Santos 100 stainless steel Automatic
mcdevito75 here, A small watch repair shop in your area can authenticate your Cartier watch for you, however here is what you can look for, the Cartier name, is it spelled correct?? are all the letters of the name Cartier the same?? if so, figure your watch is the real deal, but the watch repair shop will know for sure.
Posted on Jun 23, 2010
I need a replacement bracelet for my Cartier 21 Chronoscaph watch?
My black rubber watch band is cracked and in need of replacement. I refuse to shell out $500 for another rubber band from Cartier. This is my first and last Cartier watch... Poor customer service on a very expensive watch.
500 per one rubber; is not expensive is a steal
Sep 24, 2010 | Cartier 21 Chronoscaph W10125U2 Wrist...
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Seiko kinetic stainless steel bracelet has snapped pin (both snapped ends still visible and flush in last flared bracelet link between watch body and start of bracelet.) How do I remove snapped pin ends...
    There are several easy to follow tutorials on u-tube. It's easier for you to look at these than for me to describe how it is done. Just search "adjusting steel watch straps"
    Sep 23, 2017 | Omega Seamaster 2541.80 Wrist Watch
    Adjust watch band for Seiko 7T94 Stanless Steel Band
    You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
    First you have to find out what sort of pins or even screws are used to keep links together.
    Examine both bracelet sides and find the side where pin ends have a groove.
    Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
    For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
    Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
    NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
    Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
    After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
    After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
    It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
    Make sure that pin ends are flush with bracelet. If needed- hit few more times.
    Job done!
    If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
    Don't forget to rate, please.
    Apr 04, 2009 | Seiko Watches
    Stainless steel band won't snap into my watch
    Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
    Another way is to use curved spring lugs (pins).
    Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
    Replacement bracelet for Tag Heur 6000 series, model #WH1151.BD0678
    I have two tag 6000. one of the watch bands broke and I found a great fix. look on ebay for a rubber band called for rolex presidents. it fits the tag and the ribbing goes perfectly with the watch style. a easy and inexpensive fix, although you loose the stainless band...good luck
    Aug 02, 2008 | Tag Heuer Link Automatic Chronometer...
    Band Replacement
    The replacement bands for the Cartier 21 Chronoscaph are a complete rip off. Get a replica one!
    Now, where can I get a replica one... anyone know please? Thanks.
    Feb 22, 2008 | Cartier 21 Chronoscaph W10125U2 Wrist...
    Fake or not
    Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
    A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
    A real Cartier will most likely be built with screws in the band instead of cotter pins.
    When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
    As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
    Oct 13, 2007 | Timex E Tide Temperature Compass Watch...
    Broken strap.
    contact Cartier. www.cartier.com Donald
    May 20, 2007 | Cartier Santos W20056D6 Wrist Watch
    Raymond Weil Parsifal W1 watch Logo
    1,942 people viewed this question
    Top Raymond Weil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Raymond Weil Watch Expert? Answer questions, earn points and help others
