Question about Microsoft Xbox 360 Console
My xbox has sound but no viedo - Microsoft Xbox 360 Console
Alpine ina w900 no viedo but have sound
check your settings for video input/format, and make sure the e-brake wiring is correct/functional.
Aug 31, 2012 | Alpine Ina-w900
My xbox 360 controllers will NOT sync , i tried looking online and i tried every posible way. But nothing worked , is it the controller or the xbox itself. it worked purfect lasst night and it fell on the...
I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Sync system first (By pressing the sync button on the system)
2. Right after you hit the sync button on the system, hit the button on the controller
Try replacing the battery's and or rechargeable battery for the controller. Repeat the sync process above.
Try another controller with your xbox or try your controller with a different xbox. Repeat sync process above of course.
If another controller works with your system than that would indicate that there is an issues with your xbox controller.
If your controller works with another xbox and no other controllers work with your xbox than there is a issue with your console.
For issues related to the xbox I would suggest contact xbox directly by calling 1800 my xbox.
If possible please rate the solution I have posted.
Aug 25, 2010 | Microsoft Xbox 360 Controller
check your video cables and make sure the video cable is not bad and then make sure your tv is on the right source for where your are hooking up to ...
Nov 19, 2009 | Microsoft Xbox 360 Console
I have a pcchips m848a motherboard I don't get a signal from my viedo card , i tried 3 prossessers, two viedo cards (agp),two power supplys, the fans work and i get a low quiet beep on start or reset and...
I just recalled an instance where I had to clear the CMOS with the jumper block before being able to post a machine similar to yours.
Check your mobo manual for the CMOS reset jumper location and switch it as directed, power up the machine briefly, power it off, replace the jumper to the original location, power the machine back on.
Did it post this time?
Mar 03, 2009 | Dell (E210882) Motherboard
No Picture
sound's like viedo card problem very expensive to replace I scraped a 50 in. because of the same problem hope this help's check pioneer referb auido viedo card's on internet usa their cheaper I didn't find out until after I scraped it $498.00 plus tax in canada $135.00 plus tax in usa hope this help's Rocky good luck
Dec 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Putting viedos
you need to convert the video to an mp4 format you can find a downloadable one pretty much anywhere on the internet.
Apr 12, 2008 | RCA OPAL M4001 MP3 Player
Viedo memory is not suficent for any program which yas working before in my system pleace get me viedo software
if the video memory is not sufficient you might need a new video card because most video card you cannot add memory to it.
Feb 27, 2008 | ASUS K8V-MX Motherboard
Kaisen P83 - Invalid Viedo File
You need "Total Video Converter" and "Xilisoft 3gp".
1st make a video with your phone. Open the file with Xilisoft 3gp.
Take note of this:
Summary:
Duration: ????
Bit rate: ????kbps
Video:
Format: mjpeg
Frame rate: ???fps
Audio:
Format: ????
Bit rate: ???kbps
Sample rate: ---
Channels: ????
Now convert a video with "Total Video Converter" using the parameters you got on Xilisoft.
I tryed and works well.
Hope this help you ^^
Jan 17, 2008 | Siemens M56 Earbud Hands Free Headset
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
