Question about HP Photosmart C6180 All-In-One InkJet Printer
My printer will not printer the page that i requested from internet information, only printed the name of it
    President:
  • 2,306 Answers
That's a common problem with the HP's, you need to go to www.partsurfer.hp.com and download the driver for internet printing and install it to your computer.
Posted on Nov 19, 2009
How do I get this printer to stop printing? I requested 1 copy from Android, it has printed over 20, still going. Is it stuck in a que somewhere?
Go into the start up. If Windows 7 go to start then type "msconfig" then go to the name and right click, select "run as administrator". Then select the Services tab, look for "Print Spooler" uncheck it, and then OK, then reboot system.
Mar 06, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Apr 20, 2014 | Netflix Computers & Internet
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
When we go to print, and view the print preveiw the print content is not shown, and does not print. All that is printed is the information from the computer (eg. page 1 of 1), but none of the documents.
Well, thanks for the info, I still need more info, please let me know the Browser's name (Internet explorer or Firefox or etc..etc..). Also please include the Name/Make of your printer. I can give you the instructions few tips here, but I don't want you to waste your time and also mine. Also, the print settings/Print preferences varies from Printer to Printer. Thanks and awaiting.
Aug 21, 2010 | Computers & Internet
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
Need to print a report of past print jobs
If you have CentreWare IS you can do the following (taken from the manual):
You can find the manual link here: http://www.office.xerox.com/userdoc/P6250/6250_Web/pdfs/reference_guide.pdf
On page 97 of the manual it states:
Using Printer Management Features
Job Accounting
The printer stores information about print jobs in a log file. The log file is stored either in the
printer’s memory or on an optional hard disk if one is installed in the printer. If the log file is
stored in the printer’s memory, it is lost when the printer is reset. It is recommended that a hard
disk be used for job accounting.
The log file lists job records. Each record contains fields such as user name, job name, pages
printed, job times, and toner and ink used. Not all fields are supported by all printers. For
information go to CentreWare IS online help or CentreWare Web online help.
The job accounting values reported vary depending on the protocol and print command used
when each job was printed. For example, using NPRINT over NetWare provides the printer
with the most information about the job being printed. When using Windows and NetWare, the
job name is often LST: or LST:BANNER. Other jobs from other ports may provide less
information about the job.
Job accounting is available through CentreWare IS and CentreWare Web.
Using CentreWare IS
1. Launch your web browser.
2. Enter your printer's IP address in the browser’s Address field (http://xxx.xxx.xxx.xxx).
3. On the right side of the main CentreWare IS page, click Jobs.
The “Job Accounting Links” page provides links that enable you to browse, download, and
clear job accounting records.
For complete information on CentreWare IS job accounting, including clearing job
information, downloading job information to a file, and job accounting file formats, go to
CentreWare IS Online Help.
Hope this helps!
WizardRepair
Jul 17, 2009 | Xerox Phaser 6250DP Laser Printer
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
Print Envelopes on HP Photosmart 7280
This is a paper size problem with the software, go to page setup and under "Paper Size" choose "User Defined" or "Custom" and fill in all of the dimensional information about the envelope and save with a name you will recognize. Now, when you print make sure you have selected the envelope from the paper list and you should be good to go. If you need further assistance, click "Ask Me" and I will answer your request as soon as I can.
Oct 07, 2008 | HP Photosmart C7280 Printer
Number of pages tracking on daily basis in hp1018 laser printer
try Printer Test page
The Printer Test page contains information about printer driver and port settings. The page also contains information about the printer name and model, computer name, and so on.
You can print the Printer Test page from the printer driver.
is it on the network? login to the printer using http://<ipaddress of printer>
other option is to contact hp support online.
Dec 12, 2007 | HP LaserJet 1020 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
