Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
I want to clean fluff from underneath the transparent front panel of my Bissell 11 7901. I have removed the screws from the bottom of the panel, but it remains firmly in place. I do not want to apply apply forceful leverage in case there is something else that needs to be done before the panel will come off. Any suggestions, please? Peter
I just did this one myself, You've done most of the hard work already.Be sure your holding tank is out and not in the way.Double check the down front screws are still out since you sent in you question. Now tweak the front section (the business end) a little up, down, back and forth to help break the suction on the seal. Grab the clear plastic front piece-just the front lip near the floor and gently lift up. If it doesn't come up easily try tweaking it or running water through it to break the seal of whatever detritus is inside which is acting like a paste and holding it together.
Posted on Jan 20, 2010
Testimonial: "Many thanks. This solved the problem by giving me the confidence to exert a little more gentle pressure under the lip of the cover and it worked. "
Does the plastic cover over the rollers come off for cleaning
There are 4 screws holding it on. Remove the two on top and then lay the unit down and remove the two underneath near the brushes. The screws are self tapping screws so it's a good idea to use the same screw in the hole it came out of.
Dec 03, 2015 | Bissell ProHeat Shampoo Bottle Assembly...
Cleaner won^t spray water
Helo There!
I the cleaner won't spray that is nit necessary mean the heater is clogged. Try to make sure if the pump is running (by listening to it, measure about 12 V on it). The pump has a hidden 3.15 A fuse in the cable harness (in a heatshrink). If that one is blown the pump won't work.
The heater is accessible after you opened up the base panel. Remove the tank assembly and look for the screws to the bottom plate. Loose and take out those, lift up the base panel carefully. Underneath, you will see a cell phone size aluminium piece connected to rubber lines. This is the heater. If you unscrew the mounting screws, lift up the heater, disconnect the rubber tubes. Take out the heater and open up by removing the screws around the edges. You can look inside, clean it if it was plugged. Assemble the pieces in reverse order and test the functions.
Good luck with your project!
May 28, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
How replace rear wheel bissell 9400?
Hi There,
Ok, so in order to get the wheel assembly back into the machine, you're going to have to take apart the machine, or at least the housing underneath of the clean/dirty solution tank, as well as the housing that the shampoo solution sits on. I took pictures to help you on this repair.
Here's what you need to do:
Step 1. Remove both the Shampoo tank and the Clean / Dirty Water tank from the machine completely and set them aside. You'll need to now remove the housing that the shampoo container sits in by unscrewing the 5 screws that I've circled in red:
Step 2. After you've removed these 5 screws, lift straight up on the housing that the shampoo tanks sits in. You'll now need to remove the screws that I've circled red to remove the complete lower housing that secures the wheels in place:
Step 3. You'll need to unhook the clear housing in the front that holds the brush cover over the bottom housing. You may just use a flat head screw driver, or something to pry this housing off the bottom plate:
Step 4. Open up the bottom housing by grabbing the raised portion of the motor housing in the back of the machine. Simply re-insert the wheels into the grooves now, and after the wheel is in place, re-secure the lower housing over top of the wheel to keep it from coming out again. The bottom plate is what goes over top of the wheel to keep it in place.
If you have any follow up questions, please just add a comment here on Fixya, and I'll do whatever it takes to make sure that you get your Bissell ProHeat fixed. I'm not just one of these "experts" that just gives you vauge information and really doesn't know or care about getting your problem fixed. My concern first and foremost is to see you get your problem fixed, and I'm happy to answer as many follow up questions as it takes to get that done. I hope this helped!
Thank you,
Chris Jones
GoVacuum.com
Jul 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bottom brush will not turn.
Did you check the drive belt? There are (Ithink) 4 screws underneath that you must remove to access that belt. It's likely the cause of your problem. Iether that or a build up of other gunk there.
Jun 03, 2010 | Bissell 3750 Lift Off Bagless Upright...
The lights which tell you if you are going at the right speed on my Bissell PROHeat Pro-Tech have stopped working. Just wondering if this could be as simple as a bulb or more serious. Also, how do you...
I have this same model and never noticed the lights telling me the "correct speed" learn something new everyday....
the clear plastic hood removes with a few screws connected to the base at the bottom. the top part snaps out. :)
Mar 26, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
How do i take the clear veiw window off of my bissell proheat carpet cleaner to clean it? I've removed the 2 screws on either side but it still wont come off.
There are 2 screws at the lower front of the clear panel. Remove both of these then lift up the panel carefully and make sure that the rubber gasket at the top of the panel is not lost. This may take a little force if you have not done this before. Assembly is simply the reverse of this process. I have one of these and do this every month to make sure thattheh Bissell keeps cleaning at optimal performance,
Oct 01, 2009 | Bissell 8910 ProHeat Clear View Upright...
The bissell proheat is leaving too much water on the carpet
Sounds as though the machine needs a good clean before using again. Remove all the dirt, grease and hair from the transparent areas by removing the covers and then reassembling. Also this can be caused by running the cleaner too fast across the carpet.
Aug 26, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Jun 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you clean the bissell steamer carpet cleaners suction front? cannot get some of the fuss from that front part. Thank you
Take off the 2 screws at the bottom, and it will lift off so you can clean it. Of course this depends on which model number you have.
Apr 18, 2008 | Vacuums
Screws on bissel carpet cleaner
Don't remember being any special screws. Bissell usually uses phillips head or cross point screws.
Mar 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
78 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
