Question about Sony Playstation 3 (PS3) Console
Ps3 freezes and turns off
When i turn my ps3 on its ok for a couple of seconds, but then it jumps and then freezes. The console then beeps and turns off on its own. The red light then flashes when the console is off. Can anyone help me? Thanks
    Guru:
  • 212 Answers
Most of the times, it is a problem of connection with your hard drive or the hard drive itself is broken.You can quickly fix the PS3 by carefully re-setting the drive.
In order to do this, you need to take out the hard drive and then once out, replace inside the PS3 the same way. Usually this is the answer to the Ps3 blinking red light problem. If the red light does not go away by applying thus method, you will have to get a new drive
the next you can follow if this does not work, in case you do not want to buy a new drive
To do it, when PS3 is on standby, hold the power button until you hear 2 beeps.
If it does go onto the video output screen, turn it off again using the
power button and once its back on standby, try holding the power again
until you hear the double beep.
Check if you see this screen and try to do a system restore (note: you will lose your profile data here, since currently you do not have option to take a backup)
else a better option could be to give the ps3 console to Sony for servicing in case you are under warranty period, however they would not repair your device and send it back to you, they send you a refurbished device in replacement to your console
Posted on Nov 19, 2009
  • tooth_pick21 Feb 23, 2011
    i did this but after i restored i started up my ps3 set the language, date, and then it froze and shut off again. does this mean i need a new HDD?
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
How does PS3 become corrupt
ok just hold the ps3 on/off button when turning on for bout 5 seconds or untill you hear a beep and also do you turn it off at the back or do you wait for it to turn off
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
My PS3 has been broken for a very long period of time. About 6-9 months now, I've lost track. Every time I turn it on my PS3, it starts with the wavy animation and the colored background, and then the...
Ok, please try the following steps :
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep a total of 3 times and turn off again. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, then 5 seconds later it will beep again and then it will beep twice quickly. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this then continue to the next step
Step 5. The PS3 will load with a menu with 6 options, choose number 5 "Restore PS3 System" and follow the on screen prompts.
Using this method should sort your PS3 out for you.
Hope this helps
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 won't get to the main menu when I turn it on
Ok, follow these steps to fix your PS3, unfortunately you will lose your save game data!!
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, beep 5 seconds later and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will load. Select option 5 "Restore PS3 system". The console will ask you if you are sure, just accept and then the PS3 will restart. All the original software will be loaded and you will need to enter the date and time and other details.
When you have done all this your PS3 should be fully working again.
Hope this helps and thank you for using FixYa
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
Got a playstation 3 ,you turn it on and doesnt load to the main screen only comes up with ps3 and then the wavy lines can u help
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not switching on
hold the on button for 10 seconds , you should hear a couple or 3 of beeps
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
Ps3 Freezes
Turn off the switch at the back of your ps3.
Turn it back on.
hold down the power button for about 5 seconds until the ps3 will turn on and then off automatically.
let go and then press and hold the power button again. it will beep once, then twice. Once it beeps twice let the button go.
ps3 will show a new menu. Choose option 3 to restore file system. Your ps3 might do the restore twice in a row and then it will work. None of your files will be deleted.
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
Starting up Problems
I found it 2 min. ago. Ok here: while your ps3 is on hold the power button on the ps3 for you will hear one beep, keep holding it then when you hear the second beep take your finger off. Your ps3 should turn off. Now push the power button while holding your finger on it again, you will hear two single beeps, then a double beep, let your finger ago and a screen should appear with six options. Chose something like reset(or restore) file data or something like that and click yes, this wont do anything to your game/music/movie/etc. files but now your ps3 shall work.
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 Freezes on startup
ok here is how you do it i finally fixed my ps3 by doing some easy steps
1.have the ps3 off with the red light on and put your finger on it until it turns on and the off again
2.take off your finger and then put it on again on the power touch button until you hear two beeps
3.it will ask you to connect a usb cable from your controller to the ps3 do that
4.after that go to the second one that says restore data or memory
do those steps and your ps3 will start working in no time
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,082 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
