Question about Gaggenau GI936-760 Dishwasher
I have been advised by a reputable tech that the motor needs to be replaced . It appears that I have GM 926-710
I have a 2007 Grand Prix. It looks like it is over heating on the gauge alittle bit. I also have no air conditioning. Should I replace the thermostat?
How many miles on it ? Has it ever been done before ? Mite as well have cooling system flushed too . New antifreeze , I think 100,000 miles it should be done at . GM had problems with stepper motors in the instrument ,these step motors control the gauge's . Have had an instrument cluster problems ? Bad step motors 03 to 06 but who's to say some where not put in 07 . I replaced a few instrument clusters because gauges not reading right. We can test this at the dealer with factory tech 2 scan tool . Do the cooling fans turn on ?
How to repair GM Instrument Cluster Speedometer Gauge Stepper
I have replaced a few in chevy cavaliers ,besides trucks .
Jun 09, 2017 | Cars & Trucks
How to do the relearn/reset after replacing ecm in 2001 monte carlo
DEALERSHIP HAS TO REPROGRAM THE NEW PCM.YOU NEED A GM SCANNER TO REPROGRAM NEW PCMS IN GM VECHICLES THE GM VECHICLES FROM 1996 UP TO 2011 HAS TO BE REPROGRAM AT DEALERSHIP, HOME MECHANIC CANT REPROGRAM IT.YOU NEED GM TECH 2 SCANNER.
Aug 01, 2011 | Chevrolet Monte Carlo Cars & Trucks
Thanks . i,m in Australia and have a chevy Avalanche Z71 , and the speedo&oil temp stoped working. i have contacted a company in the States and have been quoted $700 to get a replacement cluster with...
unfortunately I know of no way to repair them, I have been a GM dealership tech. for years and have replaced hundreds of them, my cost on a cluster is like400 and their easy to replace really. cheaper would be one from a salvage yard that would work your odometer would just not be accurate
Jun 17, 2011 | 2005 Chevrolet TrailBlazer
Monitor shows 'Remove Lens Cap' when it has been removed! the shutter also appears to have failed. Can you advise please?
It appears lens assembly got broke for some reason and need to be replaced. Qualified camera tech will take apart lens mechanism and will replace broken/ cracked part to get camera back in function.
Hope this will help.
Thanks.
Apr 15, 2011 | Panasonic Lumix DMC-FZ5 Digital Camera
Speed ometer in the dash gives inaccurate reading while the digital reading in the widnshield appears to be correct. Fuel gauge has rapped around forward and temperature guage is off.
The problem here is your "Stepper Motors" are failing in the Instrument Cluster. If your Vehicle has "LOW MILEAGE" it may still be covered under factory warranty. Check with your Dealer first! If not covered under warranty, most reputable Speedometer Repair facilities can service it for you. All "Stepper Motors" in the Instrument Cluster should be replaced at the same time as the OEM versions are prone to ultimate failure.Typically, there are 5 or 6 dependent upon whether or not you have a Tachometer. They are: Speedometer, Temperature, Oil Pressure, Fuel Gauge, Volt Meter and Tachometer. The replacement part must have X25 168 where the X indicates an improved model.
Dec 12, 2009 | 2004 Buick LeSabre
Speedometer on my 2005 yukon is stuck
have your panel changed. should be covered by recall warranty
Dec 18, 2008 | 2003 GMC Yukon
Speedindication Error
Yes, The motor and motor control board are not talking to each other. The motor has a built-in tach that signals the board as to its' position and speed. One of the two is faulty. This is an expensive repair. Parts will cost between $225 and 325 depending on where you are. Make sure the repair tech has a good reputation before proceding or do it yourself.
Dec 23, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Gaggenau GI936-760 Dishwasher Logo
48 people viewed this question
Top Gaggenau Dishwashers Experts
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
