Question about Whirlpool Royal A-909 Bathtub
I have an Aker whirlpool tub that I need a pressure switch for. The manual for a newer model has a button switch mounted on the tub with a plastic tube attached to it and it goes to a small module that looks like an extension cord end. It has both a male and a female end, and the tube goes in the side of it. I guess when one presses the button it exerts enough pressure to close (and open) the connection. You plug the tub pump into it and then into the GFI outlet.
  • 119 Answers
Contact the manufacturer for a replacement switch or go to a pool and spa store to match it up
Posted on Nov 23, 2009
Repairng the air button on jacuzzi tub
Richard,
There are two pieces to an air switch, one is the bellows button which you push to turn the pump on and off, the other is the air switch located on the pump with a plastic tube coming out of it. In the newer models the switch is located on the top of the pump in a small black box secured by two screws. My money is on the switch on the pump, I have rarely seen a bellows go bad. You might want to find some aquarium pump tubing and attach it to the tube location on the back of the pump, fill the tub and blow into the tube. If the pump comes on, its the bellow, if the pump does not come on then it is the switch located on the pump
Jul 14, 2014 | Home
Aker swirlbath manual
Any manuals for the Aker by Maax bathtubs will be available directly from Maax, who makes the Aker brand bathtubs.
Feb 22, 2014 | Home
Find air switch for aker swirlbath
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off. You need part # TBS-310
US Parts Center
Feb 14, 2014 | Balboa HydroAir Magna Series Spa Eyeball...
My Aker Swirlbath pump hums but ther is no water action when I turn it on
Air Switch Repair
US Parts Center
Jan 11, 2014 | Home
The air switch on my Kohler whirlpool tub, when depressed will not start the motor. However, if I take the plastic hose off the switch and blow into it, the motor starts fine. I've replaced the ai
There are Air Switches (at the motor or control box) and Air buttons (on the spa/bath side). The vinyl tube between them is the only other component to the 'switching' on/off a hole in the tube may cause this problem.
The air switch has a diaphragm which is activated by the air in the tube when the button is pressed. If the air pressure is not sufficient the switch will not operate.
As you've replaced your Air button, you might want to change the tubing and either adjust the Air Switch or replace it. The switch only needs 1-5psi to activate so the pressure from you blowing into the tube can damage the diaphragm in the switch.
Jul 04, 2012 | Home
Where can I buy just the brass trim on the jet for my whirlpool tub (aker)?
The trim for any brand whirlpool (w/p) tub must be ordered from that specific tub manufacturer. They will need to know exactly what your particular model is.
The model of your w/p tub, and serial number, is most often, but not always, located on the motor end of your unit but not on the motor itself. Access to this end of the tub, if installed to code, should get you the information you need, otherwise you are out of options'
Jun 03, 2010 | Whirlpool Royal A-909 Bathtub
I have a 16 year old Aker whirlpool tub. Recently the tub turned on with no one near it. I had to turn the breaker off so the motor did not burn out. It appears the air switch has failed. How do you...
If it is an air switch, the switch itself is located on the pump.Locate the air line that goes from the button and follow it to the pump. It is possible to replace the switch with the pump in a accessible location. If not remove the pump and replace the switch on a work bench. The switch is inside the black or blue box located on the pump motor. Hope this helps.
Aug 30, 2009 | Whirlpool Royal A-909 Bathtub
Kohler Whirlpool tub motor wont turn on
We had the same thing happen to our Aker brand whirlpool tub.  The fix was a replacement timer/control piece which is connected by two wires to the pump behind the tub (access wall) and plugged into the outlet; however, this cost $150 for the part and $85 for the service call (all he did was take the part out and ship me the replacement part which was easy to do).  Problem I have now is that the motor won't shut off unless I unplug it.  I am waiting for a call back from the repairman who sent me the part.
Jan 11, 2009 | Kohler 1209-LA-0 Hourglass Whirlpool with...
Washer does not want to start spin cycle
Check your lid switch. This is a common failure with this model washer and it is a simple repair. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
Some washers have the lid switch under the right-hand side of the wash tub opening and is activated through a small slot on the wash tub casing rim by a small plastic piece on the lid called a lid strike. If this is the type you have, make sure the lid strike is still intact or the switch will not activate. Check the two mounting screws next to the slot and make sure they are present and tight. These are the mounting screws that hold the lid switch in place. If they come loose it can prevent the switch from activating.
Newer models have the lid switch mounted under the washer casing in the left-hand rear adjacent to the left washer lid hinge. The switch is activated by a rod on the lid hinge. Sometimes a simple adjustment of this rod can correct contact problems.
If you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Let me know if you require further assistance or part sources. I hope this helps you.
Jul 03, 2008 | Whirlpool Washing Machines
Whirlpool washer
I'm assuming you have a top load Whirlpool washer with buttons and knobs, instead of electronic controls.
There are some things that will cause a washer to overfill. The only one that will cause it to underfill is the pressure switch (water level switch.)
Some older machines (15 yrs+) have a ***** on the back of the pressure switch to adjust for the fullest load. If that ***** has moved, that would explain the lower levels. If the pressure switch is plastic (nearly all newer models,) the switch is not adjustable and should be replaced.
Mar 11, 2008 | Washing Machines
Whirlpool Royal A-909  Bathtub Logo
556 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
