Question about Dell Dimension 3000 PC Desktop
One of our computers has lost internet connection; the start/task bar have changed color as well.
    Brigadier General:
  • 3,513 Answers
Hi
You don't think much about your computer's "Start" bar (formally known as the "taskbar") until, perhaps by accident, you find it at the top or side of your screen and wonder how it got there. The fact is, you can customize many things on the Windows taskbar. From the color, to what icons are displayed, to its postition on your screen, you can customize it to your preferences in just a few simple steps..
* Change the color of your start taskbar by right clicking on any open area of your desktop. Select "Properties" and then the "Appearance" tab. Select the second drop down option which is "Color Scheme." Your standard Windows options are Default blue, silver, and olive green. Select your color of choice, and then select "Apply." Wait for the computer to update and the start taskbar to change color
For losing internet connection...
You try with another network card... Try this to:
start, run, cmd, ping 127.0.0.1, if you don't have answer, or the answer isn't constant your network port is start to die.
And how i said up, install a network card and try with this.Also, upgrade the network driver of the PC.
However Network-connection problems are infuriating. Finding their source requires a step-by-step approach. Before editing your Registry for the umpteenth time or tossing your router into the trash, run through this network-troubleshooting checklist:
Temporarily disable your software firewall. It sounds dumb, but often it's your firewall that's blocking your network connection. Even if the firewall has worked flawlessly for months, a small configuration change or automatic update could have caused a problem.
At least twice this year, Windows XP users of Check Point Software's Zone Alarm personal firewall have lost their ability to connect to the Internet due to a Windows update. Windows Secrets contributing Editor Susan Bradley described this problem in her Oct. 16 Patch Watch column (paid content).
This alone is not a good reason to stop updating, though. It's true that patches can introduce problems with firewalls, but subsequent fixes that remedy the issue will often appear within 24 hours.
Check the physical connection. Make sure the router, modem, and other network devices are plugged in and powered on. Are the network cables between PC and router still connected firmly? With a device's power switch off, it doesn't hurt to unplug the component and then plug it back in again to make sure the contact is solid. If weak power-cable connections are ruled out, simply powering the devices off and back on can sometimes be all the resetting your network link needs.
Renew your connection. Changes elsewhere on the network can sometimes knock out your connection. To reconnect quickly, click Start, Run in XP (or press the Windows key in Vista), type ipconfig /renew, and press Enter.
Update your firmware and drivers. Makers of routers and network adapters may be caught unawares by patches to operating systems (such as the ones in Vista noted above). But the vendors often issue firmware or driver updates that fix the problems. Check the support pages of your router and adapter manufacturers' sites for downloadable updates.
Return to default settings. Often, we are our own worst enemies as we poke around the configuration settings of our routers and network connections. You may not remember that you turned on your router's MAC filtering, but doing so could have blocked all of your devices from connecting, just the same.
In general, it's best to change settings one at a time and observe the results of the change before making any other alterations to your system. If you don't see an obvious way to return your hardware and software to their default settings, you may have to uninstall and reinstall the device or program to regain its original settings.
In all fairness, Vista isn't the only version of Windows that experiences network glitches. XP has its own series of connectivity aggravations, as you can see by a search-engine query of Microsoft's support center.
If your connectivity problems aren't resolved by using the points discussed above, you may be suffering from an even more obscure issue. If so, ruling out the tricky configuration problems I describe here may at least help you isolate the real problem and restore your network link.
Thanks for contacting fixya.com
Posted on Nov 19, 2009
USB modem very slow connected
You can try the following method
STEP:1
JUST GO TO YOUR COMPUTER SCREEN TASK BAR THERE U WILL FIND A CONNECT TO OPTION CLICK ON THAT.
STEP:2
A WINDOW WILL ARISE THERE U CLICK ON SHOW ALL CONNECTIONS
STEP:3
CHECK YOUR RELATED OPERATOR CONNECTION AND BY RIGHT CLICK ON IT SEE ITS PROPERTIES
STEP:4
IN PROPERTIES GO TO CONFIGURE
STEP :5
IN CONFIGURE WINDOW U WILL FIND A USB MODEM SPEED ...JUST CHANGE THAT SPEED TO 921600 AND CLICK ON OK ...
JUST DISCONNECT YOUR MODEM AND THEN CONNECT AGAIN YOU WILL FIND A GREAT AMAZING SPEED LIKE BROADBAND INTERNET.. You can also check your internet speed from ScanmySpeed.com to ensure the change in your internet connection.
Dec 26, 2014 | Computers & Internet
Correction on the previous question. I have lost internet explorer, can any tell me how to get it back. Thanks.
if this is windows 7 go to start menu and type in the search bar "internet explorer" without quotes. once you find it right click on it and pin to task bar.
Sep 27, 2013 | Computers & Internet
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
Feb 05, 2013 | Lenovo ThinkPad T410 Notebook
Internet explorer task bar missing
Try pressing the left Alt key alone. Does the menu bar appear?
Try right-clicking the area where the menu bar is supposed to be. Try different spots around the upper part of the window, eventually you should see in the context menu an option to turn on the menu bar.
Jul 09, 2010 | Dell Dimension 8400 PC Desktop
Cannot Log into Yahhoo messenger
1. First, ensure that your computer is connected to the Internet.
2. Confirm that your password is not hacked by loging into your yahoo email account with the same user ID that your using to login to the yahoo messenger, by going to http://mail.yahoo.com.
3. If you are able to log into your email account, your ID is safe.
4. Try to kill yahoo messenger on your system using "Task Manager"
5. To open Task Manager, right click on your computer's task bar at the bottom and click on "Task Manager".
6. Next, click on the "Process" tab in Task Manager, select "YahooMessenger.exe" and click on "End Process" button.
7. If you cannot find "YahooMessenger.exe", then select "Ymsgr_tray.exe" and click on "end process".
8. Now start your yahoo messenger again and try to login. You should be able to login succesfully.
9. If your Internet connection is fine and you have followed the above-mentioned process and still cannot login to yahoo messenger, your system's fire wall is probably obstructing yahoo messenger to access internet.
10. Change the necessary settings on your firewall to leverage access to yahoo messenger.
May 15, 2010 | Yahoo Messenger
I have lost my Menu Bar and have tried going to the Control Panel
try using your menu key on your keyboard. its next to the Ctrl key, that will bring up your start menu which shuld also show the task bar. right click on the task bar and click on properties. make sure "auto hide Task bar is not checked. and lock task bar. you may also have lowered it below your view. try moving your mouse pointer down at the bottom of the screen and see if your pointer turns into an arrow., if it does hold the left mouse button and move it up untill your task bar shows.
May 09, 2010 | Toshiba Satellite A135-S2276 Notebook
When I go on line, the two small computer icons do not show on the bottom tool bar. I believe the problem occurred when I uninstalled a program that helped speed up the computer and manage start up. I now...
Click on Start,click on control panel, click on Network and Internet and Connections, Click on Network Connections, The two small computer icon should be displayed. Right click on this icon,select properties. At bottom of this window check box to display icon on task bar, click on OK. close all windows.
Oct 13, 2009 | Microsoft Windows XP Home Edition
Task bar is grey upon start up
^Try going do the display properties again but this time on the Appearance tab.
You will have a dropdown box and select windows xp default.
let me know if it helps
Jun 20, 2009 | Microsoft Windows XP Home Edition
Task-bar & start-menu disappeared
Sounds as if the video card is going down. This is a common problem on these laptops. Have you checked Device Manager to see if the drivers are installed. Hit Win key and pause then select hardware and Device Manager. If nothing seems out of place there then I would most certainly suspect the video card. This is part of the motherboard and not replaceable.
As another check try connecting the laptop to an external monitor via the VGA connector at the back. The resolution problem should be resolved then.
Dec 08, 2008 | HP Pavilion dv6000z Notebook
Dell Dimension 3000 PC Desktop Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
