Question about Marvel Refrigerators
I have a mini fridge, model 61ARWWO that is on the lowest setting but is freezing everything. can you suggest any trouble shooting tips?
  • sblatney Nov 19, 2009
    i will try this and let you know if it works.
  • 10,515 Answers
First and foremost, do you see any ice in the rear of the freezer?
If yes, take a blower and melt it. Keep it off for few minutes, and then turn it back ON, say 2 hours.
Now, Take a Vacuum and clean the Evaporator Coils. Then by keeping the Back Cover Off, you could also clean the Condenser Coil.
Now, to be precise with solution, there could be 4 other reasons :-
1. If the Model does not Defrost, it might be Faulty Defrost Board located in the Upper Right Hand Ceiling Section,, behind the light cover ( On Most Models ).
2. Faulty Defrost Heater
http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php
3. Faulty Defrost Thermostat
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php
4. Faulty Defrost Timer
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosttimer.php
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 19, 2009
My Haier mini fridge is not freezing, what do I do?
Contact the distributor or check the user manual. Or failing this google your IPad or iPhone for trouble shooting.
Oct 29, 2016 | Haier Televison & Video
Haier minifridge freezing everything
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
Apr 10, 2014 | Haier Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Black and decker mini refridge freezes food on lowest setting
The lower the setting the colder the fridge should be, the dial should be turned to the right. A refrigerator should be kept around 35-36 degrees F
Jan 03, 2012 | Food Processors
The frig is freezing foods, and it is set at 1 The freezer is also set at 1 the trouble shooting guide says this is happening to go to the next lowest setting. So now what?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 27, 2011 | Refrigerators
Hi. The fridge part of my fridge freezer model HNMF2805AL80 is freezing my food , it is set at its lowest setting
My HNMF2805AL80 did same. Replaced control moduile - still freezing. Have just replaced fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just put sensor inside fridge at back - so far so good, will let you know.
Nov 24, 2010 | Hoover Refrigerators
We have an older Amana freezer on top fridge. It is set on the lowest cold setting but in some areas of the refrigerator things are freezing. Also there is an energy saver switch --which is "ON"-- left or...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Amana ATB1832AR Top Freezer Refrigerator
My fridge keeps freezing everything even on the lowest setting - does it need a new thermostat?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Hotpoint RLA30 Compact Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Refrigerators Logo
24 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
