Question about Compaq Computers & Internet
At start up my monitor will show black horizontal (even vertical sometimes) lines. If I turn off the monitor it does not help, if I turn off the computer it does not help, if I disconnect my modem and then reconnect it stops the problem, but of course it reoccurs. Any ideas?
    Problem Solver:
  • 5 Answers
I think virus attack in your hard disk or remove ram and start the computer after some time shut down comuter and again attach ram in memory slot if your problem not solve then check your motherboard
Posted on Nov 19, 2009
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
A very thin vertical brun line in the middle
If it's a straight vertical or horizontal line always in the same place it's a panel issue which the average user even with repairing skills will not be able to reliably repair ,Sorry.
Samir
Feb 25, 2008 | Dell UltraSharp 1905FP LCD Monitor
Horizontal line problem
Cl;ick on Link Below, Good Luck.
LCD Help
Helping you with questions and issues you may encounter with computer LCD displays. ... you would receive a solid black line going vertical or horizontal.
Please dont for get to Vote, Thank you
Dec 16, 2007 | HP D2835 17 in. CRT Monitor
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
Monitor
capacitor (either ceramic or electrolitic) that connect to vertical ic (TDA8173 or TDA 9302) is short or open. Check all capacitor in vertical range. tq
Nov 22, 2007 | IBM E74 17" CRT Monitor
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Computers & Internet Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
