Question about Compaq P110 21" CRT Monitor
Compaq P110 21" CRT Monitor that is blurry in the middle of the screen and clear and crisp on the edge
I've purchased a second hand Compaq P110 monitor and recently realised that the centre of the screen is ever so slightly blurry and that the edge of the screen is clear. I have tried degaussing it and playing around with the settings to no avail. I am assuming that this is just the tubes getting old. Am I right to assume this? Is there anything else I should look at? Furthermore, if it is the tubes, should have them replaced? Where?
Thanks,
    Scholar:
  • 57 Answers
As a result of aging monitor alignments drift, giving rise a a myriad of odd symptoms. Open the monitor up (of course it's got to be off), locate the scanning coils on the neck of the tube. Right there on are disk-shaped permanent alignment magnets. The scanning coils are electromagnets that produce the raster (scanning pattern), while the low-strenght permanent magnets allow the alignment to be varied ever so finely. Chances are that this alignment has drifted. Reconnect and turn on the monitor and with something being displayed, turn the disks one-by-one, observing the effect on the screen (a large mirror in front of the monitor would help much). Note that normally the disks are secured at the factory using hot glue. You may want to warm up the glue before starting the re-adjustment to make it easier to turn the disks. I am quite certain that this will solve your problem.
Posted on Jan 11, 2008
Compaq 7540 screen is blurring and what is the reason behind that?
It could be EMI by the monitor, or it could just be failing. Try the following.
1. Do you have speakers or other electromagnetic sources (walkie-talkie, cell phones, etc.) sitting close to the monitor? If so, try moving them away from the monitor. They will effect how the electrons from the electron guns hit the color phosphors inside the monitor tube making the display blurry.
2. Try running a monitor diagnostic to check if the monitor is finally failing.
Post back how it works out.
Jan 03, 2014 | HP COMPAQ 7540 CRT Monitor
I have a Compaq 7500 monitor. The screen image has compacted to a shape roughly like this ) ( in the middle of the screen. It was accompanied by a slightly burning smell. The first couple of time
Most monitors have adjustments for contrast/brightness, display position, display height and width, and one called pincushion. The last one changes the flatness or curvature of the edge of the display:
Jan 18, 2012 | Compaq CV 7500 17" CRT Monitor
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of 1024x768@85 hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
Purchased my S5 IS second hand (buyer beware!) and everything seems to work perfectly except the viewfinder is blurry. I can just make out the wording of the info around the edges but end up reverting to...
Pls. turn the little knob near the finder untill you get clear picture inside finder, previous owmer might have turn the knob for his eye sight good luck.
Nov 07, 2010 | Canon PowerShot S5 IS Digital Camera
I have a 10 yr old Sony tv that is blurry
No, most likely scenario is that the cable company compressed the signal further so they can stuff more channels on the wire. The cable guy is caught in the middle of this. The poor guys will tell you anything to get you to turn your head, then they slip out the door. He can''t do anything and the company is looking at the big dollar. I don't think you will have much luck pushing back to them. I hope this helps.
Mar 17, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Yesterday the picture was clear in in the middle of the tv, but blurry on all the edges. Now it is blurry everywhere
the cables in the backpart of the tv may be bad connected to resolve this problem reconect them again or just check the manuals for help
Jan 26, 2010 | Samsung TX-R3080WH 30" TV
My compaq sr181nx diplay monitor is now blurry
This could be a faulty monitor. Trying plugging in a different monitor to the computer.. If you continue to have the same problem with the second monitor, then it is your video card or on board video that is going out. If the video is fine after you tried the second monitor, then you need to get a different monitor for your system.
Jun 14, 2009 | HP Compaq Presario SR1810NX PC Desktop
Problems controling brightness of monitor
well its not first hand ever.
its a vacuum tube CRT relic, why own such a thing>
the monitor old and weak, ask all such monitors are.
why pop for this. and end using junk like this again.
good luck with the VIRUS magnet XP,
you dont need a driver for any monitor
$30 wopping bucks, the price of freakn, potted plant.
why deal in 50lbs of glass and VACUUM??????
why walk past this deal. and walmart
https://www.walmart.com/search/?cat_id=0&facet=condition%3ARefurbished&query=computer+monitor&sort=price_low#searchProductResult
Jun 12, 2017 | Compaq P110 21" CRT Monitor
Looks blurry, wanting a clear & crisp picture.
In the picture settings, you can choose between hdtv and standard t.v.. That should work for you because not all channels broadcast in the hdtv signal.
Jul 16, 2017 | Televison & Video
Sony 24'' CRT widescreen GDM-FW900 blurry after initial on
CRT shorts are common with this model and focus problems are a major symptom. however, the loud 'pop' you described leads me to believe that the flyback transformer may have a problem in the focus divider portion. replace the flyback, if that fails then the CRT is most certainly the problem
Nov 20, 2008 | Sony GDM-W900 24" CRT Monitor
Compaq P110 21" CRT Monitor Logo
443 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
