Take off the needle plate. There is a bracket near the front right area of the bobbin case. It is the position bracket that supports the case. First smooth the case of any rough edges, the put it in place and loosen the screw of the position bracket and align it in an area that will keep the case from spinning. There should be about 0.5mm of distance available when you use your finger and push the case from left to right, between the case and the bracket. Remember that the thread flows through this area, the case is held in place by the bracket but not tightly.
My husky star c 20 has stopped sewing. The wheel turns hard and when I try to sew the needle makes a jerky motion. In the past I have taken on the metal cover, taken out the bobbin case and brushed out the lint and it would sew for a hour and then the same problem again. I have had the machine checked out and no problem has been found. I am ready to throw it away.
