Question about Lexmark P4350 All-In-One InkJet Printer
When i press copy the carriage shoots across and
When i press copy the carriage shoots across and hits the right side with a bang, carrier jam appears on the top of the screen and below a note_clear the carrier jam.there is no jam on carrier
    Genius:
  • 1,018 Answers
The slamming of the carrier past the forward stop cause a reported carrier jam.
You should have the printer serviced by an authorized Lexmark Servicer.
Don
Posted on Nov 19, 2009
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Printer carriage stall/stuck
  1. follow the steps below
  2. Reconnect the power cord to the back of the product.
  3. Press the Power button ( ) to turn on the product.
  4. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position
  • With the product turned on, disconnect the power cord from the back of the product.
  • Unplug the power cord from the power source or electrical outlet.
  • Check for any paper or objects that might be stopping the carriage. CAUTION: If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams can occur.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove any loose paper or obstructions found.
  • Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right.
  • Close the carriage access door.
  • Reconnect the power cord to the product and to the power source.
  • Reconnect the USB cable to the product.
  • Load plain paper in the tray.
  • Dec 19, 2009 | HP Office Equipment & Supplies
    Error caused by paper jam - but there's no paper jam
    the carriage (carriage stalled) in jammed in the right side of the all in one, try slowly free it, also check cartridge status.
    (carriage stalled in process of cartridge cleaning)
    May 22, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
    I have a carriage jam
    Turn the power on. Goto the procedure to replace ink cartridge, to get the carrier in the middle. Turn off power by unplugging the machine, if you hit thee power button the carrier will go back to the right. Take your hand and move the carrier to the right then to the left. You are feeling for binds in the print shaft or any obstruction. If the print shaft is binding clean and oil it. If the cartridge is hitting something locate and repair. There is a thin strip behind the carrier that has black strips all along from left to right. This strip is called an emitter strip. That strip allows the circuit board to know where the carrier is at. The strip gets dirty and can cause the carrier to get lost to the circuits. Clean it. There are more step that you can take but they get more technical. The above mentioned can be done with out taking the cover off. You may resolve the problem.
    Nov 19, 2008 | HP Officejet 7210 All-In-One InkJet...
    Dell AIO 924 Carrier Jam Problem
    To clean the encoder strip, perform the following steps:
    1. Power down the printer and unplug the power.
    2. Lift the cover on the printer.
    3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
    Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
    1. Plug in the printer and power it on.
    2. Open the cover to allow the cartridge carriage to center itself.
    3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
    Figure 2: The encoder strip to the left of the cartridge carrier.
    Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
    Carrier jam on printer
    There could be 4 possibilities.
    1. Ink cartridges lids are open which is not allowing cartridges to move freely.
    2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
    3. Encoder strip is Dirty.
    4. Encoder strip is Out of position.
    Solution:
    1. Open the front cover and check if ink cartridges lids are properly snapped in.
    2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
    Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
    3. Cleaning the encoder strip:
    a. printer should be off and disconnected from power.
    b. open the front cover.
    c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
    d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
    e. Close the printer and try again to print.
    4. Repositioning the Encoder strip.
    a. Remove the power cord from the printer.
    b. Open the front cover.
    c. Gently slide the ink cartridge carrier to the middle of the printer.
    d. Gently move the top part of the printer belt to the right.
    e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    h. Once the encoder strip has been re-seated, close the scanner lid.
    i. Re-connect the power cord to the printer and try again to print.
    Incorrect position of encoder strip
    Correct position of Encoder strip
    Hope it should fix the issue.
    Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
    Clear carrier jam
    In your case It seems like the Encoder strip is broken or its out of printer . However if you see encoder strip inside the printer connected from left to right, try these steps.
    Solution:
    1. Cleaning the encoder strip:
    2. Repositioning the Encoder strip.
    Oct 26, 2008 | Dell 924 All-in-One InkJet Printer
    Dell phto 924 clear the carrier jam
    Solution:
    Oct 10, 2008 | Dell 924 All-in-One InkJet Printer
    Carrier jam
    your encoder strip(a transprent strip behind the carriage) is either broken or loosed up and so it is not able to get self aligned.kindly fit the encoder properly or change the encoder if neccessary.encoders are usually very cheap.wish u luck!!
    Apr 28, 2008 | Lexmark P4350 All-In-One InkJet Printer
    System error 000 carrier stall Presss power Key
    Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
    Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
    Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
    Oct 19, 2007 | Lexmark X85 All-In-One InkJet Printer
    Lexmark P4350 All-In-One InkJet Printer Logo
    529 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
