Question about Adtran Computers & Internet
Configure dhcp/nat adtran 608
How do I configure dhcp/nat for an adtran 608
2 Suggested Answers
anandg27
  • 1272 Answers
SOURCE: I want to set up network access thru an Adtran
To setup network access through Adtran Total Access 608 router I would suggest you todownload the manual for the product from the below link:
Manual
Regards
Anand Gupta
Posted on Mar 24, 2011
How can I changes my NAT-type from NAT-type strict to NAT-type 2 on Playstation 3? My router is a Gigabyte GN-BR01G
By default the IP address should be set to 192.168.1.254, insert this in the browser. You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
Click the Virtual Server link near the left of the page.You should now see a new menu. In this new menu, click PPPoE/DHCP/Static.
PSN requires you to forward the following ports:TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658 Go ahead and enter the settings shown above into thePPPoE/DHCP/Static Configuration menu.enry.png When you're finished, click Submit near the bottom of the screen to save your changes.
And that's it! You're done!
Jul 27, 2011 | Computers & Internet
Where are nat settings
Hi Friend,
As per your query regarding the NAt setings, please follow the steps:
1. Open the router page
2. Once the page is open, click "LAN IP Setup" which is in the left pane under "Advanced".
3. Check the box "Use Router as DHCP server" and define the Starting and Ending IP Address.
This way you will be able to configure the NAT settings of your router.
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | NetGear WGR614 Router
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Jun 23, 2009 | Adtran Total Access 850 Router...
How to configure my paradyne 6381 router
Go under LAN setup and enable NAT and Firewall services. Then go to LAN configuration to enable the dhcp server. Set the Start IP range and ending address.
Feb 24, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
Router no connecting to the internet
You need to configure NAT on the router to permit the entire LAN to access internet
Example.
LAN Segnment is 192.168.1.0/24
1. Create an access-list to identify the local segment
2. Configure the Nat interfaces properly (NAT-INSIDE, NAT-OUTSIDE)
3. do the NAT configuration
i.e ip nat inside source list (ACLNUMBER) .....
Dec 08, 2008 | Computers & Internet
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Dual Routers?
Disable DHCP in the router. Connect the modem to a LAN jack on the router. You'll have 3 LAN ports. If you need more ports, buy a hub. (You can change the default IP address on the Linksys, but you can't forward through 2 NATs.)
Apr 27, 2008 | Computers & Internet
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
220 people viewed this question
Top Adtran Computers & Internet Experts
David Payne
David Payne
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
