Question about ATI Computers & Internet
I cannot get my Radeon HD4350 PCI-E HDMI card working with my Windows 7 pc running Intel 915P4. Normal pc functions are ok but video playback & tv functions do not work. problem appears to be related to recognition of pci express device which driver reinstall does not allow to override default microsoft driver with ATI driver from catalyst download. HELP??? please
  • 3 more comments
  • alex_keay Nov 19, 2009
    Thanks Jennifer for your advice. I did the following:
    1. checked windows update = ok
    2. reloaded catalyst 911 vista32 - windows 7 - reboot in between. showed success
    3. cannot view any video card under device manager
    Only error showing is Intel (R) 915G//P/... PCI Express root port - 2581
    " your computer systems firmware does not include enough info to properly configure & use this device. obrain a firmware or bios upgrade (code 35)
    Looking at the MSI forum|: there is a similar problem which seems to suggest that I am stuck as the mfctr of my pc no longer exists Evesham Vale who OEMed MSI (Intel motherboards).
    Do you know of any other work around? Or if I went for a PCI graphics board (accepting some loss of performance) would i be able to overcome this problem?
    Thanks.
    Alex
    Re: help needed with graphic card upgrade
    « Reply #5 on: 20 August 09, 06:13:59 »
    What is the exact name of the MB? Example: 915GM4-F. Look between the PCI slots for the name. Likewise exact model of the CPU, as connlaoi said the current description of it is confusing. Can't be dual core as none of them are supported on the 7133 MB. These are the 3GHz P4 models I find supported: Pentium 4 530(J), Pentium 4 531, Pentium 4 630
    As far as Crysis goes even people with some of the newest hardware complain about gameplay with it.
    OK, looks like I need to put this thread to sleep. It just hit me that this is an OEM MB in an Eversham PC. Sorry, MSI and this forum can only offer support for MSI retail products and not OEM like this one that you have.
    Topic locked.
    Topic locked.
    ? Opened up PC - MSI-915GM4 7133 VER:10 printed on motherboard.
    ? ? On bootup device manger showing error above. Same message as with new graphic card
    ? No graphics card showing up under device manager anywhere
    MSI website: http://eu.msi.com/index.php?func=proddes...
    CPU
    ? Supports Intel® Pentium 4 / Celeron D processors in LGA775 package.
    ? Supports up to Pentium 4 5xx, 6xx(EM64T) and Celeron D 3xx sequence processor.
    ? Supports Intel Hyper-Threading Technology.
    ? Supports 533/800MHz FSB
    Please refer to CPU Support for compatible CPU; the above description is for reference only.
    Model 915GM4-FI 915GM4-FI H 915GM4-F 915GM4-L
    PCB Version 1.0 3.1 1.0 1.0
    BIOS Version 1.xx only 1.xx only 1.xx only 1.xx only
    Net work Gb Lan, IEEE1394 Gb Lan 10/100 LAN
    RoHS pass NO NO NO
    Testing:
    1. Playback of sample video under media play works ok
    2. Playback of video clip from camera media player works ok
    3. Playback of DVD in drive does not work ?error message below
    Media centre functions of live TV or playback of recorded tv does not work:
    Error message =
    Files needed to display video are not installed and are not working correctly restartwindows media centre.
    Trying to force the driver update of the 915G PCI Express Root port:
    ? Tried the Intel 915 Chipset express updates
    ? The tried to force the driver update by doing a manual update
    ? Unfortunately Windows says I already have latest driver installed!!! Aarrggh
    ? When I uninstall it & reboot... it then reappears with same error message.
    MSI Reminds you :
    1. Because of the limitations of chipset, this MB does not support Win98/ME.
    2. Intel 915G Series board supports Wind 2000/XP only.
    3.Please use MSI Live BIOS tool to upgrade BIOS of this product.
    ? MSI Live BIOS tool does not work ? fails.
  • alex_keay Nov 20, 2009
    Thanks Mark,
    I will try this when I get home.
    Just 1 clarification question...
    when you say;
    First thing you need to have is the current .net installed, then
    Uninstall completely using driver cleaner in safe mode and reinstall with security software and firewall turned off and internet disconnected.
    What exactly is that component & how can I check I have the right version/component?
    Also with the uninstaller tool do I need to direct that at any particular software component or is it a generic registry cleanup?
    thanks for your help.
    cheers,
    alex
  • alex_keay Nov 23, 2009
    Mark,
    I'm going to try this again as previously I did not have 3 versions of .net installed.
    I did follow the order of uninstall, regclean & resinstall CCC in parts but did not make any difference.
    1 question: IN the ATI CCC install it installs something called the Visual studio 2005 distributable files.... do I still need that to install or is that replaced by the .net components?
    I just want to make sure I'm folllowing the exact sequence that you did to get this to work.
    1 other question: should it be necessary to disable the onboard Intel 915 card at a BIOS level as the bios setting I currently have seems to allow both the PC- Express bus card (ie. ATI Radeon HD4350 to boot) & then the onboard VGA (Intel). Reading the warning message at the end of the ATI CCC install process it states other card detected. Is this relevant or do I ignore it?
    thanks for your advice to date. Will persevere to see if I can get this ATI card working.
    Alex
  • 3,741 Answers
Yes its necessary to disable the on-board Intel 915 card at a BIOS level or you can select and keep it as default setting so when ever you ON the selected card remains selected. and yes you can cross and ignore it.
thanks .keep updated.
Posted on Nov 23, 2009
  • 19,396 Answers
Try using the upgrade advisor.
It will scan the computer for potential issues with your hardware.
Here is also Download link for the drivers.
Posted on Nov 20, 2009
  • 728 Answers
Hi alex_keay,
Now instead of using the ATI all in one package driver/CCC. install the CCC first and then the driver only (in this exact order). For some reason, if i install driver first, you'll get the resolution but you won't be able to isntall the CCC. If you install the CCC you'll have the CCC program but you can't open it until you install the driver afterwards. The fun of being on the bleeding edge. Good Luck, Mark
  • Mark Taylor
    Mark Taylor Nov 20, 2009
    Hi Alex,
    The .net component can be found in your programs. If you go to your control panel and click on add or remove application, it should show up their. There are multiple versions of .net that microsoft came out with. .net 1.xxxx version 2.xxxx and version 3.xxx the current versions is 3.5XX
    You should really have a copy of at least one of version 1,2 and 3. Each .net has different processes for different applications that people write into their programs. Usually, when you install a program it may tell you that you need to install this added program and provide it for you. But, lately, programers are assuming all computers have it. Not necessarily true. After you check to see if you have .net (which is free) you can find it HERE. for version 2, which was most commonly used. You can find links at the bottom of that page for other versions.
    The uninstaller is a register and software clearner made by Microsoft, and it goes in and cleans up what you've already uninstalled, but unfortunetly again, programers get lazy and don't erase all traces of their product, especially in the register. So, Microsoft came up with this program that compares what you've earsed and what remains, and deletes any left over debrie. So, once you click the link and save it to your desktop, just run it and it does what it's suppose to, without any intervention on your part. So, yes, it's generic but also built by the guys that created this mess in the first place.
    What your going through I"ve been through personnally, and the method was by trail and error, but it finally took hold when I did it in the order suggested.
    Hope this helps!
    Mark
  • Mark Taylor
    Mark Taylor Nov 24, 2009
    HI Alex,
    The Visual studio 2005 distributable is separate from .net, so your fine installing that. And you shouldn't need to disable anything on the board.
    The order that I took was as if I had just installed OS 7 for the first time, and made sure that there was no left over ATI files or CCC. From that point I install the CCC only. rebooted which it required, Then it came up in VGA mode, since the driver wasn't installed and OS7 had no traces of it. At that point I knew I was in the clear. Then I installed the drivers and it worked. Oh, you know, have you updated OS7? I did it after a reinstall of OS 7, since I noticed that some of the drivers that OS7 was installing during their updates were conflicting with my card. I have the HD 5870, If this is a new install of OS7, you might want to reinstall it over any updates. Let me know.
    Thanks
    Mark
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
By default, Windows 7, installs a "generic" driver for all video graphics cards. A way to install the newest one is by doing this:
Download and install the new driver (I assume you have done this already). Go to device manager and right click on video graphics card that needs the driver. Right click and choose "update" driver. Lead the path to the new driver.
This will force the driver in and it will be accepted.
I would like to let you know that during the beta testing, radeon video graphics cards were having many issues. Since then, Microsoft has released updates for Microsoft 7, I believe close to 56 already.
It is always a good idea to perform the updates manually and make sure they are all installed. To do this, go to start menu and search for windows updates. Open the updates box and run update, download and install.
Please let me know if this has helped or if you have further questions.
Posted on Nov 19, 2009
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Nov 19, 2009
    You know, when I had problems with my Linksys adaptor (while trying the beta of Windows 7) I searched everywhere online. This one guy came up with a quickfix type driver that solved my problems. I bet you can find the same if you look around. Meanwhile, I will see what I can find on it also.
  • Jennifer DeLaCruz
    As for the intel error message, you will need to reinstall the chipset driver. This can be found on intels website.
How to connect monitor to Radeon HD 5570
Well the radeon 5570 has 3 0ptions first i VGA all the monitors support VGA. The second id HDMI it is the best choice becouse it also has the ability for audio playback. And of course the DVI if the monitor supports it.
Dec 02, 2013 | HIS ATI RADEON HD 5570 PCI Express Video...
Drivers windows
Without being more specific I can not help you much.
All I can say is to update you drivers.
Oct 28, 2013 | ASUS EAH4350 SILENT-DI-512MD2-LP- ATI...
Radeon hd4350
Yes It should work with your system. Another thing you may want to look at is upgrading to windows 7 or 8. If I remember correctly this system shipped with vista which is a huge resource hog and will slow down your computer even more.
May 29, 2013 | Computers & Internet
What graphics card can be installed in a Sony VAIO VGC-RB30 using Windows 7?
Hi Jose,
Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card. Is one of the compatible cards you can put in the system and can be sourced from
http://www.memorygiant.com/video-card/sony-vaio-vgc-vgcrb30-vgcrb30c/
Regards
Proton
Oct 02, 2012 | Sony VAIO RB30C (VGCRB30) PC Desktop
Mi problema es con el ciberlink powercinema 5, cuando lo abro la tv se escucha pero no se ve y se queda pillado el ordenador, tengo windows xp sp3 pro.
It can be the TV Tuner Card.See this:
Operating System
  • Microsoft Windows 7, Vista and XP SP3* (Windows XP Service Pack 3 is required)
Processor (CPU)
  • Blu-ray Disc playback: Pentium 4 541 (3.2 GHz), Athlon 64 X2 3800+ or above
  • TrueTheater 3D playback: Pentium D 950 (3.0GHz), AMD Athlon 64 X2 3800+ or above
  • DVD playback: Pentium 4 (2.4 GHz), Athlon 64 2800+ (1.8 GHz) or above
Graphics Processor (GPU)
  • Blu-ray Disc playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 7600GT or above
  • TrueTheater 3D playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 8800GT or above
  • DVD playback: AGP or PCI Express graphic accelerator supporting DirectX 9.0 or above
    • Note: we strongly recommend that you update your graphics card driver to the latest version. 3D display devices are required for TrueTheater 3D playback.
Memory
  • Blu-ray Disc playback: 2 GB required for Vista and Windows 7; 1 GB required for Windows XP
  • DVD and TrueTheater 3D playback: 1 GB required for Vista and Windows 7; 512 MB required for Windows XP
Hard Disk Space
  • 300 MB for product installation
Display Device
  • DVD and Blu-ray Disc playback: HDCP compliant display for digital output. TV or computer monitor for analog output
  • TrueTheater 3D playback: 3D display and 3D glasses required. HDCP compliant display for digital output. TV or computer monitor for analog output
Disc Player
  • Blu-ray Disc playback: BD-ROM/BD-RE or Super Multi Blu combo disc drive
  • DVD and TrueTheater 3D playback: DVD-ROM, DVD+-R/RW, DVD-RAM or DVD Super Multi combo disc drive
Microphone
  • A microphone is required for recording voice-overs in Movie Remix mode
Internet Connection
  • Internet connection required for web services
Dec 20, 2010 | Microsoft Computers & Internet
Upgrade compatibility continued
hiya
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Rik
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Need help disableing onboard video, and installing PCIe video card.
Hi rebelel1271, I do have the manual for you're Intel motherboard. You can have it as well. Click on the link below to download you're manual. document.write("D101GGC Product Documentation & Manuals") D101GGC Product Documentation & Manuals
Intel states you do not need to make any bios changes when you add a PCI-Express video card. See this on page 17, PCI and PCI Express Auto Configuration. Before installing you're PCI-E video card, open windows controll panel. Than open add/remove programs. Look for the driver software for you're onboard ATI Radeon X200. Uninstall that software. (If listed). Close all opened windows & shut down windows. Unplug the power cord from the PC. Open the case. Install you're new ATI Radeon X800 PCI-E video card. Double check all internal connections, (In case you may have bumped loose any cables). You're X800 may also have a 3-pin or 4-pin male power connector built on the card. If so, plug power to the X800.
Intel D101GGC driver page.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21#DOC
ATI's web site for the latest driver's.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
A little information. Once you're PCI-E has been installed. You're system memory will increase.
Good Luck!
If I can help you further, feel free to post here.
Mike
Jun 01, 2008 | Intel D101GGC Motherboard
Computers & Internet Logo
59 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
