Question about Sony Playstation 3 (PS3) Console
Dead ps3 no lights
Dead playstation3 no lights
no fan
silent
there is a faint electrical click when mains lead connected
but otherwise nothing, any ideas?.
    Problem Solver:
  • 27 Answers
You should go **** some ****
Maybe it will work then.
Posted on Nov 19, 2009
So I have ASUS silent sqare pro CPU cooler for about 6 months, but the little blue thingy that shows the fan speed died, well it still shows the speed of the fan but the nice blue light is dead, it just...
Either the blue LED is faulty or the LED needs replacing or resoldering to make proper electrical connection.
If you cannot fix it yourself and the fan functions normally then don't worry about it.
Jul 07, 2011 | ASUS Silent Square Pro - Processor cooler...
My computer runs normally.. all of a sudden, my computer stops working. i try to power on the computer. nothing happened as it is dead. i remove the side cover. the green light for the...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 02, 2011 | ASUS P5GD1-VM Motherboard
When i go to put any disc into the Playstation3, it doesn't respond by taking it. No gears move or anything, it just acts as if there is no disc to pick up. How can i get my Playstation3 to take a disc so...
This is a problem occurring in all the play station 3 consoles....... this is mainly because of the poor quality of the disc,.....as a result it leads to the damage of ur PS3 lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Dec 09, 2010 | Sony Playstation 3 (PS3) Console
In replacing a broken pull chain (no 3-way power here: simple pull-on/pull-off) on the 3-bulb light fixture of my fan/light combo ceiling appliance, I lost track of how to re-attach the two black wires...
I assume the switch operates the lights only. Besides the ground (green or bare) and the neutrals (4 white wires all connected together), the only wires of interest should be 4 wires (black) from the fixture and the 2 wires on your switch. Of the 4 black wires, one of them is the hot wire and the other 3 connect to the three bulbs. Connect the hot wire to either one of your switch leads and connect the other 3 wires to the other switch lead.
If you don't know which of the 4 black wires is hot you can find it by the process of elimination as follows---- connect any three of the black wires together (then supply power), if nothing lights, then the 4th wire is hot. Otherwise 2 bulbs should light. Remove one wire from this trio. If nothing lights, the wire you just removed is the hot wire. Otherwise, one bulb should light and one of these two remaining wires is the hot wire. Take one of those last two wires and connect it to one of the other bulbs. If it lights, then the wire you just moved is hot. Otherwise the one you left behind is hot. I hope this is helpful. Good luck. Be safe! Al K
Aug 03, 2010 | Westinghouse Electric Ceiling Fan 3-way...
My playstation3 stopped working on 23/5/10. very hot day. now it starts momentarily then cuts out within 1 second. red light flashes. then an amber/yellow light. help
your ps3 has a under powered fan... you will have to mail you ps3 in to get fixed.. they will give you a ps3 they fixed. The new ps3 will have a more powerful fan.. but it will bug the **** out of you.
May 24, 2010 | Sony Playstation 3 (PS3) Console
When trying to start my 94 DeVille it was completely dead. Absolutely no dashboard lights or other electrical response except for a very faint but high pitched noise that seemed to be coming from the...
Sounds as if the Alternator is not charging, alltough it could be a bad battery. Check the connections on the battery and make sure the cables are tight. Jump the car again, and if it starts check the alternator for output, it should be putting out close to 17 volts if the battery is dead. If the alternator charges then you probably have a battery problem, and need to replace the battery.
Apr 24, 2010 | 1994 Cadillac DeVille
Playstation3 cant turn on><
try turning the main swith on and off a few times, then power the front.
let me know
thx
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't show up on tv
first make sure all componet cables match up in color in back of the tv turn on ps3 and try using the remote to change the componet selection of the port your using
May 14, 2009 | Sony Playstation 3 (PS3) Console
Playstation3 problem
maybe because you havent updated your ps3 to what the requirement is for your games
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 trouble
ok, i got it working... Ok...your problem is probably that when you're using it on the HDTV...you have the resolution set to an HD one (720p, 1080i, 1080P). A normal TV cannot display these. While it's connected to the HDTV,Before you connect it to your normal tv, you have to switch it back to 480i or 480p otherwise, your regular tv wont show a picture. So go to settings, display settings, and uncheck 720p, 1080i, 1080p. It will ask you if these are the settings you choose (and it's going to look funny on your HDTV) Accept the settings and turn it off. When you connect it to your Regular TV, you should now see a picture. Hope this helps!
Dec 13, 2007 | ViewSonic N2060w 20 in. LCD Television
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
