Question about HP Photosmart C6180 All-In-One InkJet Printer
My Sony Vaio won't print using my printer HP C6180
My printer was working now it's not. I have two macs connected with an airport to my printer HP C6180 they print fine. So did my Sony Vaio and then it stopped printing and I can't get it to print again. I downloaded the driver from HP for Vista for my printer and still it wont print. I saw another post for this on your website and tried that solution but that didn't work either. This is the mother of all problems.....Help
  • 1 more comment
  • gunsandyoga Jan 21, 2008
    Wow, I have the same Hp Printer and the same problem!
  • Anonymous Apr 05, 2008
    I am having the same problem with my Vaio laptop operating system vista. My printer just stopped working. I've removed the printer & software from the laptop and reinstalled (advised by HP support) and it worked for 1 day and won't print again. Is there any help out there?!
  • execdir May 29, 2008
    same problem -- was working for months - stopped. other computers on the network use a usb port to access the shared printer. This is not an option on the sony. if you chose "add port" it is still not an option.
    New Friend:
  • 22 Answers
Is the ink of your printer there?? Or finished. Check this n then try to print again
Posted on Jul 15, 2017
  • 16 Answers
SOURCE: HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Posted on Jan 05, 2008
SOURCE: My Sony Vaio won't print using my printer HP C6180
lol ur just noobs
Posted on Sep 23, 2008
SOURCE: Does HP laserjet 1020 work with Airport Express
I removed any printer configurations for this printer in both my pc and my mac (both usb and wireless). Then I restarted both computers and added the printer via usb again to each. At that point I went back to the extreme configuration and under the printers tab it was finally seeing Hewlett Packard Laserjet 1020. After that, adding via Bonjour went smoothly on both platforms.
Posted on Oct 18, 2008
FixinFax
  • 3085 Answers
SOURCE: HP Photosmart C6180 All-in-one Offline mode
Go to www.hp.com. let the PRINTERS section auto-detect your printer and download the drivers automatically.
Posted on Jun 28, 2009
Printtech
  • 1087 Answers
SOURCE: Lexmark C530dn won't print with only black
To configure the printer to print in black only, please click on the link provided below.
http://bitly.com/r97CV6
If you need further assistance, please contact Lexmark Technical Support.
Posted on Oct 12, 2011
Radio on C6180 not working and printer won't print
Try to unninstall the driver then put it again, it should work
Dec 05, 2011 | HP Photosmart C6180 All-In-One InkJet...
I can't get my Canon pixma mp480 to be seen by my computers when it is connected to airport express. Will it work with airport express?
To print using Mac OS X v10.3 or v10.4
  1. Open Printer Setup Utility (located in the Utilities folder in the Applications folder).
  2. Select the printer from the list.
To print using Mac OS X v10.5
  1. Choose System Preferences from the Apple menu and click Print & Fax.
  2. Click Add (+) and select your printer from the list.
  3. Click the Add button.
  1. Install Bonjour for Windows from the CD included with AirPort Express.
  2. If you do not have the CD, download Bonjour from here
  3. Follow the onscreen instructions for connecting your printer.
May 09, 2011 | Computers & Internet
Can't get psc 1610 to print on new macbook wirelessly
If you install the Hp wireless driver on your Mac, that should do it.
Aug 18, 2017 | HP PSC 1610 All-In-One InkJet Printer
F380 connected to airport express - usb /cannot print
Look for the drivers for F300 series - you may need to download them from HP's site. They're generic, but they work - unless you're trying to print through Airport!
Oct 14, 2008 | HP DeskJet F380 All-In-One Printer
Airport Express, Bonjour Printing Does Work With Leopard
In the setup of the Airport network settings, you have to make sure that AppleTalk is actually turned on (or the box is checked). When using Mac's with Leopard and you use both the ethernet port and airport off and on, the OS tends to deactivate AppleTalk. Its not a set thing, just random.
Jun 27, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Networking HP officejet 4315 with PC and Mac
Here's how to solve the print problem from the Mac. I still haven't figured out how to solve from a PC yet.
http://discussions.apple.com/thread.jspa?threadID=1258091&tstart=191
Feb 24, 2008 | HP Officejet 4315 All-in-One Printer
Using my airport
as far as i rember apple os, you hve to delete the printer which was connected through usb cable.
Disconnect mfc from mac. Connect the mfc to airport. restart airport and after that your mac. the mac os should find the printer.
anyway, some info can be found here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Feb 05, 2008 | Brother Multi-Function Center MFC-240C...
HP Photosmart C6180 All-In-One InkJet Printer Logo
151 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
