Question about Candy Washing Machines
Shows 11 on display and makes strange sound - Candy Washing Machines
I found the manual for the machine online.
Posted on Nov 21, 2009
Imovie '11 in imac. For some strange reason several songs and video have no sound when placed in iMovie. How can i fix this?
If all songs or videos have no sound then replace or repair its speaker, if some songs or videos have no sound then it can be say that it have a problem with songs and videos. If those songs and videos are working at another PC or Imovie then it need to get watched to any mobile repairing shop or buy another.
Oct 20, 2013 | Apple Ilife 11 Iphoto Imovie 11...
Goes to start and quits already replaced fuel pump checked for fire out dist and coil and have fuel pressure
This may sound strange, but, disconnect the battery for about 20 minutes and then reconnect it. This will reset the computer. Also, check the battery voltage and make sure it is above 11 volts.
Sep 30, 2010 | 1995 Jeep Grand Cherokee
E20 showing on display, machine still got water in
E20 is related to the pump and as you say a strange noise is there I would check the filter for foreign objects.E90 is normally a communication problem between the main programmer and the display module.There may have been a fault in the pump which has caused a fault at the Programmer.That model was first produced in 2002 but it is worth checking pump and filter first.If you find anything in filter then clean it out and give it another go the E90 error may have been a glich.Best of luck.
May 04, 2010 | Zanussi FJD1666W Front Load Washer
Whirlpool duet washer shows error message "F 06"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jan 29, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
My P-73 sometimes has a strange purple /greenish color on the display like it is not rendering the colours correctly. Also it shows a strata of lines. Often in bright sunshine. But sometimes OK. Any...
Please open its cover and re-insert its CCD assy flexible cable it is loos thats why purple and greenish color appear. Its part no and description is 1-860-194-11 FP-854 FLEXIBLE BOARDeedc66b.jpg
Jan 24, 2010 | Sony Cyber-Shot DSC-P73 Digital Camera
Similar problem here...Lenovo T61p won't power up.
Sounds like it needs the magic reset procedure. Press the power button 11 times and on the 11th time hold it for 30 seconds. Put the battery and power adapter in and retry it.
Nov 24, 2009 | Lenovo ThinkPad T61 Notebook
Problems with the display screen of Roland XP 10 synthesizer
Try this link:http://www.sweetwater.com/sweetcare/ If the info isn't there, contact them and describe your problem exactly and they will help.
Nov 24, 2009 | Audio Players & Recorders
COMPAQ N610C DISTORTED DISPLAY?
Sounds like video failure. If your video is integrated as most laptops are, it will require a motherboard replacement.
Jun 27, 2008 | Compaq Evo N610C Notebook
Benq 7220 display wrong color
It sounds a lot like a bad color wheel if it was a DLP. IF it is a LCD then i would say one of the LCD panels is bad or possibly a connection problem that drives the panel or the connection that hooks up to the projector is suspect. Let me know if that helped you at all.It is strange that the bottom shows white though. Jay
Jan 30, 2008 | Office Equipment & Supplies
Computer making strange noise
This is not a problem most people experience this. Its just your fan making noise monstly because it is touching some wire inside. You don't need to worry about this.
Nov 07, 2007 | Computers & Internet
Washing Machines Logo
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
