Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Water does not come out when button is pushed
    Scholar:
  • 190 Answers
Check these items:
(1) When the trigger is pulled, does the rubber pad behind the tank seal on the handle get pressed down? A rod in the upper handle presses this rubber valve to dispense water/soap.
(2) Are any hoses kinked closed at the bottom pivot point of the lower handle, where attached to base?
Posted on Nov 20, 2009
IS IT NORMAL TO VIBRATE LOUDLY WHEN PUSHING RED BUTTON TO RELEASE WATER? I RENTED ONE TODAY. IT PRETTY MUCH IS QUIET TILL I PUSH THE RED BUTTON.
Red button activates the pump, brushes and suction is my guess and pumps can be noisy. You could phone the rental place and ask. As long as it cleans your carpets, all is good.
Feb 17, 2016 | Rug Doctor Wide Track Carpet Cleaning...
It died on me, but I probably had something to do with it. The hand attachment was still working, and I went to move the canister when I noticed that the water was not swishing around. Then I looked on the...
Hi You should have empted the water out of the canister before. The water has gotton in the motor and you may have shorted it out. Some vacuums may have a reset button. Push and try again.
Good luck
Jun 20, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Water will not come out when i push on trigger button. So water does not come out. I have taken it apart and cleaned it. The problem seems to be in the triggerI push on the handle to release the water.
order the part from bissel see if that fixes sound like you know what wrong just need get part number from bissell.
Could be some kinda pump also thats bad not pushing out the water.
I got bissle heated one black it only problem the seals rot out the soap dispencer. if you want be cheeper on washing things you can water down dish soap ore laudry deterget on there unit and cost allot less 17 bucks for bottle soap water
Jul 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
May 25, 2009 | Rainbow 75th Anniversary Canister Vacuum
I have a Saeco Armonia Espresso Machine. The water pump was running when the tank ran out of water and when I refilled the tank, it wouldn't start again. I unpugged it and turned everything off overnight....
Common on Armonia...
There is no water in the system, so the pump is pumping air!!
you have to push on the usual button but make sure the hot water button (for tea for ex) on the right side (same as steam opening valve) of the machine is open. This will allow the water to re-flow through the system. Once water is coming out again, close hose, and stop water button. Once hose is closed, and you repush the water button, it will flow again through the coffee hole.
Voila
Nov 30, 2008 | Saeco Vacuums
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Cleaning solution continually runs from clean solution tank
Where is the water running out? If at the bottom of the tank, is the seal on where the tank sits on, Maybe the rod inside the handle is staying pushed down, the reservior asm is bad, or a water line is off.
Feb 12, 2008 | Hoover F5881-900 Vacuum
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
119 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
