Question about Whirlpool GSC278PJS Oven
I need the bottom bake element for my kenmore 911-4298814, s/n OA63768. Sears is telling me parts are no longer available. Where can I find after market parts for a 20 yr old oven
  • Whirlpool Master
  • 3,361 Answers
Take the element to any appliance parts store. They can match it to a usable element.
Posted on Nov 19, 2009
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Lower oven bake element not working
go to sears and take the serial numbers off your appliance and they will get you a new element for it and you can take the old one out and the new one in. Ask them at sears how to do it and they will tell you.
Dec 11, 2011 | Ovens
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Oven issues. when on bake does not come one but when on broil it does. stovetop works fine
Hi, W/D here.
The problem is that your baking (lower) element is broken and needs to be replaced. This can be done by yourself.
1. Trip the breaker.
2. If the stove unplugs, unplug it. Verify that all power is off. If you have a meter, test the power at the leads to verify that the circuit is "dead".
3. Gain access to the bottom element and disconnect it.
4. Take your old one with you to your local appliance parts supply house (they'll have an exact replacement, and are much faster than ordering one through Sears).
5. Re-assemble in reverse order.
Best regards,
--W/D--
Jan 22, 2011 | Kenmore Ovens
Oven takes 20 minutes to fully heat on bake - Kenmore oven plt095-2
if its a gas model most of the time you will have a weak oven ignitor. if an electric,check to see if the bake element gets hot ,some ovens will bake with upper and lower elements so if only the upper works it will take much longer to pre-heat.good luck!
Jan 16, 2010 | Kenmore Ovens
Kenmore oven not heating, stovetop burner are ok Model 790.953203
When we moved into this home in 1985, it was 7 years old, and all appliances were Sears Kenmore brand. All died within 6 months. Have never entered a Sears store since. Sorry to be a spoil-sport. We have, ever since, purchased at a local appliance store.
Mar 03, 2017 | Kenmore Ovens
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool GSC278PJS Oven Logo
145 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
