Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi 55" tv problem
About every 30 minutes screen turne blue and audio & video are lost. turn tv off and then on i get everything back again for about another 30 minutes.
at one time i had the blinking green light and i replaced the capacitors with
4 - 25vdc caps from Radio Shack. these were in the dm. Could this fix be the flux of my problem?
  • 2 more comments
  • no84 Jan 11, 2008
    It did it again and I did as suggested. The error code flashed was 1 flash followed by 2 quick flashes. What does that
    mean? Thanks.
  • no84 Jan 12, 2008
    mean? Thanks.
  • no84 Jan 17, 2008
    Sorry, but I don't have an esr meter. I'm not sure but I think the caps I used as replacements wer 25vdc and 1000uf. I am sure
    though the caps I replaced were all together.
  • no84 Jan 24, 2008
    The fuses are good. I checked all inputs and found that 1, 2 & 3 are not recognized when screen turns blue but the card slots are but the are very distorted. The analog or rf input is ok. Any ideas?
  • Mitsubishi Master
  • 8,617 Answers
When it shuts down, try pushing the input and menu buttons together on the tv and hold them for 5 seconds , and see if it blinks a 2 digit code . If it does let me know the sequence of the blinks. If not then its not going into protective shutdown, so its probaly one of the low voltage regulators. Let me know what you discover with the input and menu buttons.
Posted on Jan 11, 2008
  • Sonny Berry
    Sonny Berry Jan 12, 2008
    12 is the code that says no problems. The 4 capacitors you replaced were the 4 all together on the upper left corner of the board Jamicon brand? You have probaly got a bad capacitor still on that board. Do you hav an esr meter where you can check the capacitors in circuit? What were the uf ratings of the caps you replaced?
  • Sonny Berry
    Sonny Berry Jan 17, 2008
    You may want to check to see if the pico fuses are still okay. They are the little ceramis fuses solderd to the back side of the circuits on the traces . Check continuity with an ohms meter.
When I turn the TV on it goes to the blue screen but nothing works then the TV powers off on its own.
Blue screen usually indicates no input. Check the input selection. Check the cables from the source. If everything is correct, try this: unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
Apr 18, 2011 | Mitsubishi LT-52153 LCD TV
Mitsubishi 55" MODEL WS 55513 1080 HDTV blue screen
I plugged my Dell desk top in and the XP screen comes up, but when windows comes on I getablue screen. Any ideas?
SimTech@gmail.com
Jan 21, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Medallion rear projection lost signal from all devices
Have you fixed this problem yet?. I seem to have the same issue.
Sep 07, 2009 | Mitsubishi WS-55513 55" Rear Projection...
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi WS-55857 55 in issue
Hello Rodfamy:
You will need to look in the small signal board section of your service manual.
Aug 10, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Tv shuts off sporadically, and now won't recieve any video signal
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
May 07, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Black horizontal lines appear after tv is on for 30 minutes
Kellia,
I had the same problem with our VS-55705 Mitsubishi. It seemed to me that this was a problem of heat.
I unplugged the TV and then took the cover off of the back of the it. I then used canned air to blow off the collection of dust from the components. Then I vacuumed as close to everything as I could without touching any of the components. I then used glass cleaner to clean up the surface of the three bulbs.
I plugged in the TV and it has worked perfect ever since. I haven't put the rear cover back on it yet. That could have been all that I needed to do to fix it. I'm too busy enjoying a nice picture to try putting it back on. Cleaning the bulbs really helped the quality of the picture.
Good Luck!
Oct 11, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
