Question about Sharp Televison & Video
Tv is on shows snow. I have checked all connections are connected. Channel changes are working , but no picture???
  • blanched Nov 19, 2009
    tv is not connected to a box but it is on cable???
    President:
  • 1,284 Answers
Are you connected to a cable or satellite box? If not you will have to have an over the air digital to analog converter since TV stations now broadcast in digital format. Please take a few moments to rate my answer. Thank you..
Posted on Nov 19, 2009
How to connect my Sharp Aquos TV to my Dgtec HD box
It will depend on what output connections the box has. Some examples:
If coax to box and coax to set: in menu make sure set to Cable or Catv and put set on channel designed for this box (usually channel 3) and turn set and box on---with this connection set stays on a channel and box provides and changes channels.
If box has audio/video outs connect to one like it on the set , a input and put set to that input--turn box on and change channels.
Box and set of course both will be turned on.
Jun 13, 2012 | Televison & Video
Getting snow when connecting polaroid tv to dish
Hi bevybab!
I would need more information as to which TV (1 or 2) you're experiencing the problem with, but if this is a new TV it sounds like you may need to change the modulator setup.
You can find the setting under Menu -> System Setup -> Installation -> Modulator Setup. If this is TV1, change the TV 1 Out to channel 3 or 4 depending on what you have listed. If this is TV2; change the mode from air to cable or cable to air and then put the TV on the channel it shows after selecting done to save the settings.
If you can provide more information or have any other questions let me know!
Tommy Faust
DISH Internet Response Team
Nov 27, 2011 | DISH Network 322 DTV Receiver
A brief history: fixya helped me change my bulb (been receiving a "replace bulb" message for awhile until my picture went black). The picture now is snow, not black which seems to me to indicate the bulb...
Since you do have sound but snow for picture is your TV 54J or 54U chassis the PT50DL54J chassis shows 4 tuners also Have you look for Leaky or Bad capacitors if they are puffed up on top they are Bad 2200uf 25v 1000uf 25v Look for bad capacitors on tuner Boards, and I have seen where they are on Power supply board that will affect Picture.
Dec 04, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Turn on DVD power and Aiwa name screen is not displayed on television. rather it is just snow. no picture when dvd is playing. just snow. even though no loose connections. please help
i assume that your connection between tv and dvd is using an rf modulator. that means you dont have video input in the tv. if this is the case, set the tv channel to channel 3 or 4. let us know.
Apr 15, 2009 | Televison & Video
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Pioneer SD-P62A3-K 62" Rear Projection...
27" Zenith Television
Assuming the picture tube lights up and you have snow when selecting the tuner function, I would first hook up a working VCR with a good tape and play it while the set is on channel 3 (if that is what your VCR is set to). If no sound or picture is displayed while the tape is playing,it could indicate a defective tuner. If you don't even get snow with no antenna connected (unless your set is designed to go to a blue screen with no signal present) then you could have a problem in the video processing circuits which would explain no picture with the RCA connections as well. This would probably make the set beyone economical repair.
Sep 15, 2008 | Zenith C27A24T 27" TV
Go video VR3845
Try unpluging the unit and the plug it back in
Apr 19, 2008 | GoVideo VR3845 DVD Recorder/VCR
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
