Question about Toshiba TEC B-472 Thermal Label Printer
How do we embed into a Windows report, commands for a Tec B472
My problem is that 180 degree rotated fields are skipped by the Seagull version 7.18 (August 2009) driver. I am using FastReport as a label designer in my Delphi application. It is a label that must be folded in 2 (ski tickets), thus the need to have mirror images of two fields on the label. The PC command allows for 0, 90, 180, 270 degree rotations with codes 00,11,22,33. The label is as follows : Adult 11/19/2009 ---------------------------------------------------------- fold 11/19/2009 (rotated 180) Adult (rotated 180) Since the 180 degree rotated fields are not picked up by the driver, I would like to embed them directly into my Windows report with some sort of escape sequence that the driver would recognise and just issue them to the printer without transforming them in any way. I have tried, but the driver generates some garbage. The printer commands generated are the following : The 2 lines in blue below, lines 5 and 6, don't get generated by the driver because of the 180 degree rotation. 1. TEC BARCODE PRINTER JOB START
2. {D0300,0776,0270|}
3. {C|}
4. {PC000;0548,0191,15,15,H,22,B=Adult|}
5. {PC001;0515,0094,15,15,H,22,B=11/19/2009|} 6. {PC001;0615,0094,15,15,H,00,B=11/19/2009|} 7. {PC000;0748,0191,15,15,H,00,B=Adult|} 8. {XS;I,0001,0000D6110|}
9. TEC BARCODE PRINTER PAGE END
10. TEC BARCODE PRINTER JOB END Thus I would like to know how to get them to generate automatically or how to embed the commands directly into the report. I would generate the appropriate values for the fields B=. Thanks, Gilles GGGolf
  • 19 Answers
Hi Gilles483,
If you want to use a printer in windows, create a Generic text printer in the correct port and send the commands.
Posted on Dec 01, 2009
Testimonial: "That is exactly the solution that I discovered myself. (Generic Text). Thanks"
Label splits
because if label lengh is ex. 20mm and you set up label print area as 21mm, it will over the size and it will skip the next one. the print area shoul be less than the label length. please verify software or driver.
Jan 22, 2014 | Zebra LP 2844 Thermal Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
Is there a way to change the setting on the Zebra S4M to rotate the print 180 degrees to match our labels?
No. The change must be made in the software that you are creating the label design in. Let me know if this helps!
Jun 21, 2011 | Zebra S4M Thermal Label Printer
I have a Zebra 105se printer. When I attempt to print labels, I am using bartender 9.4 to create the labels, the printer will not print using the full label. Instead it uses only the last inch of the...
Check to see what printer driver you are using. If you are using Seagull Scientific Bartender, you will need the printer driver from Seagull Scientific for it to print properly. You can download it from the Seagull website. Hope this helps!!
May 25, 2011 | Zebra 105Se Thermal Printer
I nstalled Zebra Z4Mplus printer drivers. is it supports to ZEBRA ZBR2303372 drivers?
shivacando: You can use the "zebra universal driver", the "zebra designer driver" from Zebra Technologies and also the "seagull driver" from Seagull Scientific Systems.
Roberto Martinez
padrino99@prodigy.net.mx
Dec 15, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
Trying to print the data from a Mettler Toledo IND690 Weighing Terminal to a TLP2844 Zebra
This printer can be loaded into memory the design and receive the data from the weighing terminal for the desired layout.
Feb 21, 2008 | Zebra Printer 140-751-00000
Toshiba TEC B-472 Thermal Label Printer Logo
471 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
