Question about Vibe CBR10 Car Subwoofer
The woofer wont turn off
My friend installed these speakers for me. He did connect a blue wire from the CD player to the subwoofer so that it automatically switches off once the CD player is turned off. However, it does not work. It might be because he connected the wrong wire, but the subwoofer does not turn on if I take the blue wire off. This is giving me a lot of problem because if I forget to remove the power wire from the Sub, I will have a dead battery next morning.
  • kmavtksuk Nov 22, 2009
    Thank you Rucker26 for replying...sorry for explaining the situation properly...the woofer I have has a built in amp so the connection are as you have explained to the amp. however I suspect the problem is in the connection from the CD player 2 the amp the remote cable). do you know much bout wiring from the CD player.
  • kmavtksuk Nov 23, 2009
    I was hoping I will hear this...lol...I did look it up on the internet and wanted to confirm it 100% before I do anything to the cd player. Thank u very much for confirming this...but there are I think 2 blue wires...just not sure which one..lol.
    Thank u once again!
  • 106 Answers
The only wires that should be going to the subs are the Speaker wire, The power, goes to the amp, Blue the remote wire should only go to the remote spot on the amp wich is usually labeled rem. and the ground all goes to the amp.
Posted on Nov 19, 2009
  • Blake Rucker Nov 22, 2009
    Yea, What you need to do is check the back of your cd player and see if the blue wire is connected to just the blue wire. And on the amp just go to the amp and look to see if it is in the REM port Also known as Remote port.
Hi. One of my zones wont work now. Bose technitions had to take my subwoofer to get fixed would that have anything to do with it. All other zones work. Right now it is hooked up to go through the tv. It...
sometimes units work in tandem,meaning if your system set up is working right when everything is connected and now its not working because the woofer is not connected then your system works in tandem, once all of the speakers are connected the system will work as it should,(sometimes these units work when all wires are connected,take 1 wire out of the equation and the system wont function properly, ( you'll be fine when your woofer gets back in line!)
Jan 23, 2015 | Bose Audio Players & Recorders
Hi, i have a 2004 dodge ram 1500 with the infinity stereo system. The factory cd player broke and i tried to install a new cd player, i bought the right wiring harrness and conected it. But the speakers...
it sounds like you need to turn on our amplifier. this is simple and easy to do just by connecting the blue/white wire off of the back of the radio to the blue wire on the harness that connects to the factory harness.
Jul 02, 2011 | Car Audio & Video
Hello, my problem is when I insert a CD(mp3), the Subwoofer gets disabled and only the speakers works. However, when I use only radio, the woofer works fine, it's only when I play CDs. My receiver is new...
it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white (amplifier remote turn on) wire to turn your amplifier on.
Jan 17, 2011 | Kenwood KDC-MP335 CD Player
When the radio is on the sound comes out of all the speakers. when the cd player is on the sound only comes out of the sub woofer
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
Apr 30, 2010 | Eclipse CD2000 CD Player
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Bazooka BTA series self-amplified tube subwoofer wont' power on
the blue wire is called the remote wire will go to back of head unit also to a bule wire that will send 2 amps to turn on the speaker only when the head unite is on
Apr 18, 2009 | Infinity BASSLINK Car Subwoofer
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
Vibe CBR10 Car Subwoofer Logo
207 people viewed this question
Top Vibe Car Audio & Video Experts
xxxxxx xxx
Are you a Vibe Car Audio and Video Expert? Answer questions, earn points and help others
