Question about Tomtom GO 740 LIVE GPS Receiver
How to restart if it freezes. Sometimes without any reason it freezes. The only way out is by draining out the battery and then it starts working.
    President:
  • 1,111 Answers
Make sure its charged for atleast two hours.
if it freezes, you can press and hold the power button for 15 seconds until it shuts off then do the same to turn it on and it will reset by itself.
Posted on Nov 20, 2009
Testimonial: "Thank you so much. "
  • Ben Dover Nov 20, 2009
    your welcome Alex.
    bill
Electrical short
Alternator's shot. You're probably running on battery only till it drains down.
Feb 22, 2014 | 2002 Chevrolet 0239 2500 Cargo Van
My phone freezes all the time, what can do to stop the freezing
The problem could either be coming from the battery, letting your phone overcharge can damage the battery witch can cause complications, or you may have to delete certain apps, such as the apps that run in the background or without your permission, witch can also drain your battery
Dec 05, 2011 | Samsung Star GT-S5233 Cell Phone
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
Fuji S7000 shuts itself down...without a reason
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
Vaio VGN-FZ340e freezes without reason!
Possibly you have a programme running in the background that is causing the freezes, could be a screensaver. i think at sometime microsoft will issue an update that will fix this problem.
Oct 15, 2009 | Sony VAIO VGN-SZ460N/C Notebook
My PC auto matically restart when turning it on
The beep you hear is your BIOS trying to alert you to an error in the POST (power on self test) routine. Without knowing the manufacturer of your motherboard one can't be certain what the beeps indicate...see this link for more info: http://www.5starsupport.com/info/beep_codes.htm
It's possible you have some kind of infestation, and it's possible there's something more systemic, but without knowing the make and model of your system I couldn't say.
Sometimes three beeps indicates a keyboard error...you could try another keyboard or unplug yours and see if it will boot up "normally" without it.
Otherwise, report back with some more info and we'll take it from there.
Mar 28, 2009 | Microsoft Windows XP Home Edition
LAPTOP WILL CUT OFF OR FREEZE UP FOR NO REASON
re-install the windows to fix that problem...
Mar 12, 2009 | Everex StepNote VA4103M Notebook
Battery not charging sometimes, drains out while driving
You have a Bad Belt Tensioner. That is Causing your Problems. If the Tensioner is not Keeping the Belt Tight you will get the Symtoms as Described Above. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Jan 30, 2009 | 2000 Mitsubishi Diamante
A whole crapload of problems.
Not a hard drive issue I'm afraid. Sounds like they switched the whole system out. So you disassembled the laptop and put it back together? That's more than most of these guys can do. You've got a loose lcd cable, or memory is going bad, or there's a short in the case-palm rest area. All these are common with this model. Good luck
Oct 08, 2007 | Toshiba Satellite A105 Notebook
Tomtom GO 740 LIVE GPS Receiver Logo
569 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
